99 7.3 powerstroke slight miss.nopower,rpm drop ,bad mpg,acts like its out of time
P0603 Internal Control Module KAM Error
P1211 ICP Not Ctrllable - Pressure Above/Desired
P1316 Injector Circuit/IDM Codes Detected
I would try swapping IDMs with someone...
Also what do you have for gauges? And what mods do you have done to it?
IDM's are very expensive. Where are you located perhaps we can find a member close to you. Or if you have a friend with a PSD. The IDM is located inside the driver side fender well. You have to pull back the liner to access it.
update
i changed ipr sensor made it run little smother but still sluggish under acceleration
i did fuel pressure test 60psi steady
did notice that when i pulled ipr not much oil came out but oil res was full of oil
all so did norther scan to day no codes but still runs sluggish
Woody4949
13
02-23-2017 07:50 AM
IH_Powered
15
03-03-2016 07:57 AM
sandfantom
16
06-28-2010 12:01 AM
