Suspension or leaf Springs for Clearance?
Hey everyone.
I have a e99' PSD as you can see in my pic. I am currently running 34" 315-75-R16's on my truck:
My truck has the 3" suspension leveling kit on it. When Im cranked all the way to the left, the tire will rub a little bit. When I am turned all the way to the right it only rubs if I hit a bump while completely turned.
I would like to eventually get 18" wheels with 35" 315-75-R16's. I want to make sure I have the clearance for these and I am not sure what my options are. I know I could spend money on a suspension lift. But I have heard of adding leaf springs or getting a new leaf spring set to allow enough clearance. There is always a body lift option but that is just a bad idea in general.
Any suggestions and links on leafs springs or suspension lifts?
Thanks!
Thanks!
If you get less backspacing then your going to rub on your fenders. I have 20" wheels with 35s and a 3" leveling kit. My wheels dont have much backspacing and they rub on the fender inside and out. But you can cutt the inside fender out to cure the inner rub but you'll still be stuck with a rub an the metal fender wich can ruin your fender and cutt your tires. IMO I would get an aftermarkef lift, thats what I wish I would have done, and prob will do in the future. Goodluck.
The more backspace the wheel has the further in it will sit in your fender. The less if has the further out it will sit and look alot wider.
If you want 35s with the 3" kit get a wheel with backspace to match around what the stock wheels backspace are and cutt the inner fender out. But if you drive rough road you could still run into rubbing issues.
You should be able to get whatever backspacing you want on an 18" wheel. What that is exactly I dont know, like I said I would try to get close to stock but it may vary an inch or two either way hard to say. I still believe your going to have rubbing issuses the same as I do, mine dont rub that much seein how I cutt out the inner fender which I would recommend if your capable.
A 4 inch lift will clear with the factory back spacing which is 4.5 as far as fender's rubbing, left and right can be corrected by welding more on the bump stop's, it stops it from hitting the leaf spring. 3.5 back spacing will do the same thing. even if you lift it 6 inches with out adjusting bump stops it will touch leaf springs if flexed enough, thats with big tire's.
