97 triton 4.6 3 codes
Old Nov 19, 2009 | 08:17 AM
robert987's Avatar
robert987
i have a 97 f150 4x4 running rough with 3 codes
1 p0174 system lean bank 2
2 p0306 misfire cyl 6
3 p0307 misfire cyl 7
vacumm pressure stays at 21 hg unless you turn on the heater (has a/c)
the egr control valve runs about 2-3 minutes after the key is off
all injectors sound alike
run solid vac to egr valve (took vac hose off fuel regulator to do this )makes no change except the egr valve leaks bad
pcv valve has lots of vacumm
could it be intake gaskets or????
Old Nov 19, 2009 | 09:27 AM
1Aauto's Avatar
1Aauto
Former Vendor
Welcome to the site.If you post this in the tech section.One of the members will reply I'm sure.
Old Nov 19, 2009 | 01:33 PM
glruff's Avatar
glruff
FTE Leadership Emeritus
Hi robert987, welcome to FTE!
Like Tony suggested, post your questions in one of the site's tech forums.
Maybe start your search here,,, 1997 - 2003 F150 - Ford Truck Enthusiasts Forums
Take a minute and introduce yourself to the local ON chapter members here,,, Ontario Chapter - Ford Truck Enthusiasts Forums
Glad you found the site and decided to join us.
Horock
New Member Introductions
Jul 4, 2013 07:44 AM
humbuds
Apr 3, 2009 07:47 PM
Red 4x4
Mar 15, 2009 02:54 PM
musubee
Nov 6, 2008 06:11 PM
