Sponsored by: Real Truck
OOOGA HORN INSTALL
Old Nov 18, 2009 | 11:55 PM
btm991's Avatar
btm991
OOOGA HORN INSTALL
IM TRYING TOO HOOK UP AN OOGA HORN TO MY UPFITTER SWITCHES IN MY TRUCK. HOW SHOULD I WIRE IT THE HORN HAS A POSITIVE AND NEGATIVE.
Old Nov 19, 2009 | 03:44 PM
bpounds's Avatar
bpounds
Connect Upfitter wire to the positive. Wire the negative to a good frame ground.
What is the current draw rating on the horn? Make sure it is not too much for the Upfitter. Probably is not, but it must be checked.
Old Nov 19, 2009 | 06:27 PM
btm991's Avatar
btm991
thanks but i just cant get the upfitter switch to pop out. do i just use a small screwdriver to po it out
Old Nov 19, 2009 | 06:32 PM
bpounds's Avatar
bpounds
Why would you want to pop the switch out? That is not where you connect the wiring.
Old Nov 19, 2009 | 06:36 PM
btm991's Avatar
btm991
where do i connect the wiring. is it the group of wires under the hood. if so which color do i hook it to.
Old Nov 19, 2009 | 06:42 PM
bpounds's Avatar
bpounds
No, not under the hood. Under the steering column, behind the fuse block.
This document should help:
https://www.fleet.ford.com/truckbbas/non-html/Q117.pdf
The wires under the hood are not connected to anything on either end, until you connect them. You will find the other end of those behind the fuse block as well, and you can use one of them to pass the current through the firewall. As long as the current is not too high.
clark grizwald
Jun 30, 2017 09:49 AM
Auburn_in
Jan 16, 2013 11:57 AM
BMWM1
Jul 9, 2009 10:11 PM
1957F100
Jun 28, 2009 12:00 AM
lee
Oct 30, 2000 12:57 AM
