Minnesota Chapter Join Chapter, Leader: fordpower88
GTG thread
Old Dec 22, 2009 | 11:51 AM
  #76
jhand124's Avatar
jhand124
My schedule looks clear, I will have to double check with the wifey though.
Things that I need to do are:
Re hook up my isolator for my fuel pressure gauge, if I can fix the leak first. I also need to change my trans fluid, anyone know how many qts are needed to do the flush? I have two cases of Schaffer's = 24 qts.
My truck will only fit into a garage with 8' high doors, so if it doesn't fit I can give moral support on other trucks, if needed.
Old Dec 22, 2009 | 12:28 PM
  #77
DieselCamper01's Avatar
DieselCamper01
I cannot answer the garage door question but 24 quarts of ATF will be good. I cannot remember the stock quantity. 16 or so maybe?
Edit: If it turns out you cannot get your truck in you can always drive as far as my place and ride with me also.
Old Dec 22, 2009 | 12:38 PM
  #78
jhand124's Avatar
jhand124
I believe it holds 17 and I have aftermarket cooler, I just don't know how many will be wasted in the flushing part.
Old Dec 22, 2009 | 01:39 PM
  #79
DieselCamper01
Should not waste more than a couple quarts. I have the tubing already from doing a flush so don't buy any.
Old Dec 22, 2009 | 02:13 PM
  #80
jhand124's Avatar
jhand124
Sweet, thanks.
Old Dec 22, 2009 | 03:21 PM
  #81
DieselCamper01
No problem Jason. Hope it works out that you can go.
Troy, how tall are your door openings?
Old Dec 22, 2009 | 05:06 PM
  #82
fordpower88's Avatar
fordpower88
Ok I went and measured the doors and one measures 95" with the door openend all the way. The other door measures 91" with the door all the way open. I know my stock height truck fits in the shorter door no problem. Jason's truck should be ok in the taller door. What is the worst we let a little air out of the tires to get it in! Once inside the shop there is plenty of room, just got shorter doors on the building. The building is layed out kinda weird but you will understand once you see it. But it is heated!
Old Dec 22, 2009 | 05:46 PM
  #83
leekingen's Avatar
leekingen
gtg
i will see if i can make it
Old Dec 22, 2009 | 09:26 PM
  #84
DieselCamper01
I think we can make that work Troy.
I hope you can make it Lee. Keep us posted.
Old Dec 24, 2009 | 10:28 AM
  #85
Excursion4X4's Avatar
Excursion4X4
Let me check the calander, and get back, but count me in for now!!! Might have a ball joint on the drivers side that needs replaced.
Old Dec 24, 2009 | 12:40 PM
  #86
fordpower88
Glad to see we are getting a few more people coming!
Old Dec 27, 2009 | 07:42 PM
  #87
DieselCamper01
Got a PM from Dale. He is in for sure. Upper & lower balljoints on his truck
Old Dec 27, 2009 | 08:51 PM
  #88
fordpower88
Sounds good Jay! I am thinking we should maybe get a list going of what all everybody wants to get done that day. Also if somebody is going to need any special tools for anything let me know so I can see if I have them. Myself I would like to replace my shocks and steering stabalizer.
Troy-shocks and steering stabalizer
Dale-upper and lower ball joints
Old Dec 27, 2009 | 09:08 PM
  #89
MisterCMK's Avatar
MisterCMK
MN get together? What is this I hear?
Old Dec 28, 2009 | 08:00 AM
  #90
DieselCamper01
Hello Chris. Any and all are welcome to join the get together. Vehicle work or just sitting around and BS'ing. Details kind of start at about post #49 I believe. If you want to join let us know. You can drive seperate or bum a ride from one of us. Tom is from NE Mpls, Dale is in Robbinsdale and I am in Maple Grove. Those are the for sure attendees from the Cities so far. I think Jason will be coming from Farmington and maybe Lee from Spring Lake Park. Shoot, I am sure i am missing one right now. Of course Troy is hosting so I am pretty sure he will be there. haha
Edit: I also think Mike (allis327) will be there from Melrose.
