So the old rusty bed is off and now its time to work on the old frame.
I have a few holes where the shock towers were and a lot of other rust, my crossmember for the E-brake cables is toast. I must cut it out and 1 find one or two fab 1 up, if any of you know where i can find a used one let me know please, Cutting off the spring perches this week and going to clean that area up but for now here are a few pics.
Look at the lmc box (new bed side in there foe my used/new bed)
come on, you can get that cleaner than that. i used a wire wheel on mine, cleaned every nook and cranny. put a couple layers of por15 on it, then some stuff called rusfre over that. i like the chassis saver alot too, hadnt heard of it when i did the ford.
Yes you are right It has to be a lot cleaner than what it is now, but i still have a lot of work to do, wire wheel and cleaning disk!!!!!
