tailgate reflector help
Old Nov 18, 2009 | 12:08 PM
hotrod351's Avatar
hotrod351
well the red tailgate reflector finally came loose. i remove the aluminum piece and popped off the grey plastic piece under the red reflector. i put some silver ac tape across the section, to cover the holes in the aluminum and give some reflection, but im not sure what is the best way to reattach the red reflector, i thought about some permatix clear weather adhesive. has any one here re-applied there reflector and what did you use. then again i guess i could buy some chrome screws and re-attach it.
Old Nov 18, 2009 | 12:42 PM
mcs58's Avatar
mcs58
My reflector came loose and like you i decided to yse screws in it i bought some stainless ones the mistake i made was using only 6 i would recomend using 8 because when it gets warm it will want to buckle
Old Nov 18, 2009 | 04:18 PM
awkoop's Avatar
awkoop
I used the clear adhesive out of a caulk gun and it has stayed solid for about 3 years.
f100beatertruck
30
Jun 20, 2022 08:13 AM
willeo6709
Jun 19, 2015 10:01 PM
kengarchow
May 3, 2014 09:01 PM
Shovelhead 93
Sep 10, 2008 07:44 PM
