Replacement alternator
Old Nov 17, 2009 | 10:00 AM
f250meangreen's Avatar
f250meangreen
Where is a good place to get a replacement alternator for my 04 F250PSD. Should I stay with the stock 110amp or go up a little? Dealer is saying the alternator is low under load. I have to find out what they measured but this will be another item added to the long list of repairs I am going through. Thanks
Old Nov 17, 2009 | 06:42 PM
gearloose1's Avatar
gearloose1
Get as much output as you can with one alternator... you will not regret it.
Old Nov 17, 2009 | 08:39 PM
Lubbockguy1979's Avatar
Lubbockguy1979
If you have a reputable alternator shop I would use them. Typically better results than autozone grade stuff and about the same cost.
Old Nov 17, 2009 | 10:11 PM
BobsF350's Avatar
BobsF350
ive used a 7.3l alternator from a start/alernator shop split the case r&r the lug works fine it was 100.00 cash
Old Nov 18, 2009 | 12:57 AM
howardq99's Avatar
howardq99
I think I will upgrade to a large case 160 amp alternator from these guys when my current alternator takes a dive...
1999 & up Ford 7.3L, 6.0L & 6.5L, High output Alternators,
Good Luck!
Old Nov 18, 2009 | 05:25 AM
bismic's Avatar
bismic
Good Luck!
Not saying they are still doing it, but on another forum a member got a "group buy" from these folks going. They messed up the order at first (delivered several alternators in a box labled something different than what was ordered). They said it was ONLY a labling issue - that he got the correct units. Then they delivered the rest of the alternators to him. Because of the order issues he checked the output of one - it did not deliver as promised. He checked a bunch more and none of them delivered what was advertised. He returned them all and we scrapped the order.
Just saying - Let the Buyer Beware.
Also - I bought a starter from them for my 7.3L truck - did not last that long. I had the OEM starter re-wound at a local electrical shop w/ a good reputation (as lubbockguy said) and it has been great for several years now.
Old Nov 18, 2009 | 06:13 AM
DSMMH's Avatar
DSMMH
I got my 160 amp upgraded alternator from below:
It fit perfect but it came with a smaller pulley then the stock which caused my belt to be loose. I swaped pulleys and have had no problems for 2 years since I did the install.
Also, I installed a second output lead from the alternator. Remember, the OEM output wire is sized for 110 amps. Increasing the output by almost 50% will probably overheat the wire, melt the insulation and reduce the alternator performance. If you are going to run more current you need more wire. I ran a second #2 gauge wire from the alternator output lug to the passenger side battery. Again, no issues with the upgraded alternator.
DSMMH
Old Nov 18, 2009 | 06:34 AM
f250meangreen
Thanks for the info. My only options so far is a 120amp at Napa for $120, 110amp at AdvanceAuto for $110, or Ford stock for $240. I just moved not to long ago and have not found any reputable shops yet. Thanks for the information, I will keep looking and hope it holds out for a while.
Old Nov 18, 2009 | 06:38 AM
bismic's Avatar
bismic
DSMMH
When you go back to the bigger pulley, you de-rate the output of the alternator. I forget the formula, but it is ratioed off of the new vs original pulley size.
Old Nov 18, 2009 | 11:43 AM
bpounds's Avatar
bpounds
I have had such bad luck with rebuilt/reman alternators, that I'm pretty much at a point where I will only buy new OEM units. At least on a vehicle that I depend on.
Y2K Ford can beat your quoted price on a Ford alt.
www.partsguyed.com
Edit: check on that price. I was looking at the wrong unit, and the list doesn't look complete. Maybe email Ed and ask him for a quote.
Old Nov 18, 2009 | 05:22 PM
gearloose1's Avatar
gearloose1
Given the number of hours required to put a new alternator in, it just doesn't make sense to risk a sub-standard unit for a small savings....
Old Nov 18, 2009 | 05:33 PM
69cj's Avatar
69cj
When you say number of hours the way you did, what kind of truck are you referring to? Don't think it's an F series 6.0
Old Nov 18, 2009 | 06:28 PM
Raul B's Avatar
Raul B
just thought i would put this out there but i have seen these first hand and know they are great alternators... they are made here locally to me and if you need prices i can def shoot one over to you
Ford Truck & SUV Alternators
-Raul
Old Nov 18, 2009 | 07:08 PM
bismic's Avatar
bismic
-Raul
Raul - thanks for the post! I have also heard good things about dcpowerinc, but good to hear it from your "first hand experience".
For another choice, I have heard that Ohio Generators is good too. They aren't cheap though!
Home
Also (FYI) -
For amperage 200 A or over, you will need 2 gauge wire for up to 5 feet; 0 gauge wire for 5 to 15 feet.
Old Nov 18, 2009 | 07:20 PM
cheezit's Avatar
cheezit
wow. 15 min. pull belt,lock tensioner. disconnect 2 batteries. 3 bolts. 1 connector, and 1 10mm nut.
ford pays us 1.9
