Lifter noise Cold start up
Old Nov 16, 2009 | 09:23 PM
twister2gt's Avatar
twister2gt
Hey was wondering how you guys would go about fixing this. What products can i try before next oil change. Could i replace just lifters without pulling cam out? 89 f250 351. It only lasts for about 5-10 seconds after start up. i run 10w40 Castrol GTX with a Quart of Lucas everytime i change oil. Truck holds 7 quarts
Old Nov 16, 2009 | 09:29 PM
1966Tbird's Avatar
1966Tbird
you can replace liters without pulling out the cam buy you've gota pull the intake manifold to get to the lifters then break them in for 20mins at 2300rpms then change the oil
Old Nov 16, 2009 | 09:33 PM
twister2gt's Avatar
twister2gt
Think i might want to try a chemical solution first. where should i start and am i using a good oil for where i live. I live in kansas city kansas, temps in winter time are between 38-10.
Old Nov 16, 2009 | 10:03 PM
quicklook2's Avatar
quicklook2
the problem is your oil filter.
which one are you using?
fram or?
Old Nov 16, 2009 | 10:41 PM
Conanski's Avatar
Conanski
Your problem is a cheap oil filter with a plastic anti-drainback valve that warps and leaks after a few hours(any cheap Fram, Q-state, Castrol, or chain store brand filters) or sludge buildup inside the motor which can be cured with some engine flushing most times.
Old Nov 17, 2009 | 06:47 AM
twister2gt's Avatar
twister2gt
I always use a Wix filter on my truck, maybe just got a bad one?
Old Nov 17, 2009 | 09:21 AM
quicklook2's Avatar
quicklook2
no reason not to use a motorcraft filter.
i just returned a wix filter that leaked on my subaru.
wix products have failed for me twice this year.
Old Nov 17, 2009 | 10:57 AM
vancouver island's Avatar
vancouver island
Is Fram really that bad. I just put one on maybe I should change it. What about Seafoam. I put that in and my oil gauge went from reading around the N to around the M, don't know if that really was the reason but That was the only thing I had done at the time.
Old Nov 17, 2009 | 11:13 AM
quicklook2's Avatar
quicklook2
fram and ford motors do not like each other.
seafoam in the oil should not be used for long.
Old Nov 17, 2009 | 12:02 PM
vancouver island
Yeah well that is good to know is their a reason why? What is different just curious. When I use Sea Foam I use it for about a Tank of Gas or a Week Then change the oil, again works well for me
Old Nov 17, 2009 | 12:08 PM
quicklook2's Avatar
quicklook2
fram has been discussed 100s of times.
do a search.
a week is ok with seafoam in the oil.
3000 miles is not.
Old Nov 17, 2009 | 12:22 PM
vancouver island
I agree, all I know is the fram oil filter made a difference so the oil in their must have been pretty dam bad. The sea foam did the trick though. A week would be max with it in. I know people that use it every 3 to 6 months. Don't know how good or bad that is I just prefer to do a engine flush.
Old Nov 17, 2009 | 01:20 PM
quicklook2's Avatar
quicklook2
seafoam IS an engine flush.
Old Nov 17, 2009 | 01:49 PM
vancouver island
Yes it can also be put in the gas as well as through the brake booster vacuum line, I however just put it straight in the TB. Was looking up about the FRAM they do not sound good at all. Gonna change mine out. Just shows that even the so called simple things should be researched.
Trap2
Feb 5, 2025 06:19 PM
bhenders
Sep 4, 2016 07:12 PM
JAMES1952
May 23, 2015 02:24 AM
asder
Modular V10 (6.8l)
27
Dec 9, 2008 03:47 PM
tk3445
1983 - 2012 Ranger & B-Series
Jun 13, 2006 02:54 PM
