bucking
Old Nov 16, 2009 | 07:32 PM
str8racing's Avatar
str8racing
bucking
On my wifes 95 f150 5.0 e40d at about 40-45 runs rough, bucks and pops. Code 311 is the only code. Checked plug wires and cap and rotor, seem ok, was new about 1 year ago. Also on pass. side behind pcv valve have something with a small white hose broken off (what is this?) Any other ideas?
Old Nov 17, 2009 | 06:40 PM
brett12396f150's Avatar
brett12396f150
Did you ever find out what code 311 meant?
Old Nov 17, 2009 | 06:47 PM
octaneforce's Avatar
octaneforce
stuck egr valve?
Old Nov 17, 2009 | 07:25 PM
Conanski's Avatar
Conanski
That's likely the cause of your bucking problem. The vacuum hose attaches to a diverter valve that is part of the air injection system, and any leaks in this system upstream of the O2 sensor results in extremely lean engine operation.
Old Nov 18, 2009 | 06:20 PM
str8racing's Avatar
str8racing
Do you know what that little line is for where it ties back in?
BOB ROSS
1978 - 1996 Big Bronco
Oct 25, 2006 06:32 PM
Sunburnt
Sep 2, 2006 12:50 PM
72F103
May 3, 2004 05:29 PM
teederj2002
Jun 16, 2003 04:33 PM
