Bench Bleeding Master Cylinder
I am about to install a new brake master cylinder. It is part of a CPP kit, originally from a Corvette.
I've installed a few master cylinders in my time, but have never bench bled one.
The kit came with little plastic tubes that screw into the fluid output ports and re-direct brake fluid straight back up into the MC reservoir. Instructions say to use these on the work bench, with fluid in the MC, and work the piston back and forth. Of course they showed a master cylinder with a push-rod protruding from the body that you could grab to push in and pull out. The MC I got from the kit does not have this, so I would only be able to push inwards and let it come out on it's own.
I could also do this on the truck, using the pedal to actuate the MC.
Just wondering what has been the experince of others with performing, or skipping, this pre-bleeding process.
Thanks,
Gustave
Thanks,
Gustave
Go ahead and bench bleed it. It makes bleeding the system much easier.
Use a screwdriver to push the piston in. It is spring loaded and will come back out by it's self. Put the end of the bleeder tubes in the fluid and bleed until no bubbles ore coming out.
Easiest if held solid in a vice.
Trouble Bench Bleeding
Hi Folks,
So the time has finally come for me to bench bleed the new CCP master cylinder. I've got it clamped in a vice, with the little plastic tubes leading back up the reservoir. Nice clean brake fluid. But I've been pumping the piston with a screw driver for some time now and absolutely nothing is happening. No fluid movement at all, just some small air bubbles coming out of one of the pin-holes in the bottom of one of the reservoirs.
Is there a trick to how you stroke the MC to get the fluid going?
All I can think of right now is to let it sit for a while and see if gravity helps me out.
![](http://gustave.smugmug.com/Trucks/56-F-100/bench-bleeding-mc/731655945_i8BDw-L.jpg)
If anyone has any tips they would be appreciated.
Thanks,
Gustave
Thanks,
Gustave
Thanks,
Gustave
turnrjr
10-30-2012 02:07 AM
51-f1-bob
05-19-2012 12:29 PM
BigMikeUGA
05-03-2012 02:11 PM
masseysbronco
10-29-2010 09:02 PM
palehorse13
05-29-2010 03:25 PM
