pinging under load
Old Nov 15, 2009 | 08:43 PM
jeffrodc's Avatar
jeffrodc
pinging under load
Hi everyone, My truck wants to ping when I am pulling my trailer with my tractor on it. I tryed premium gas, that did not help.I also set the base timing, it still does it. It does have a vacuum leak I noticed, when I start it , there is a whistle sound until it warms up. I am thinking this might be my problem ? Is there a common vacuum leak problem on these motors? 1995 f 250 hd, 5.8 motor, e40d trans ,123000 miles Thanks ,Jeffro
Old Nov 15, 2009 | 09:46 PM
rla2005's Avatar
rla2005
Common vacuum leaks are everything attached to the manifold. Seriously, every rubber and plastic vacuum hose are suspect as well as the reservoirs/components they are attached to.
When was the last time you changed plugs/wires/cap/rotor? Have you tried pulling the codes to see what the PCM thinks is wrong? How did you set the base timing and what is it set to?
If it is making a whistling noise it should be easy to track down the source.
Old Nov 16, 2009 | 09:01 AM
jplinville's Avatar
jplinville
Spray a little carb/choke cleaner on and around the vacuum lines while engine is running and listen for a change in engine idle. That should lead you in the right direction for tracking down the leaks.
Seriously, tracking them down on these trucks is much easier than it was on my Mercedes...took 3 months of weekends to find and repair them all just to get the car running properly.
Jimmy Pet
Modular V10 (6.8l)
127
Aug 4, 2019 01:21 PM
Boba Fett
Jun 17, 2015 06:39 PM
Steve Drewel
Nov 28, 2013 09:38 AM
pursugr
Modular V8 (4.6L, 5.4L)
Sep 28, 2007 05:24 AM
dsmith1484
May 24, 2003 05:58 PM
