i just got a hpx line from pure diesel performance and its long enough to go from the front left of the block to the rear right of the block. it wont go straight across cause of the length and the angle of the fittings i cant make it work. will it work the same if i run it from the front left to the rear right?
Well guys ive done searches and cant find what im looking for...this the first time i havent got a replie and to be honest with yall its a little disappointing. any help is appriciated, thanks in advance.
alright, thanks guys. i think i may be able to run it like you both have yours set up so i will give that a try tomorrow and if not i may go have it shortened. thanks again.
I got mine from Oldbird... he got a Adrenaline HPOP which regulates the oil for you so he didn't need it anymore. I don't recall which company makes it.
The steel hard line and the braided stainless lines are the best...
yoslick that is where I got mine. Personally I would contact Clay at RiffRaff Diesel Performance. He will probably get you a better deal. And he has hard and soft lines too.
I've been happy so far with my Riffraff steel HPX. To use it on an OBS though you'll have to move one of your HPO lines to a different plug, Clay's HPX goes straight across.
well i tried to run it like the pics but it wont work. im not gunna waste time returning though , im just gunna have a buddy shorten it cause its a soft line and hes got hydraulics class...lets hope it works good when its not 5in to long.
