Exhaust Leak
Old Nov 15, 2009 | 02:07 PM
Fully_Loaded's Avatar
Fully_Loaded
Exhaust Leak
Well from time to time I have smelled exhaust in the cab. Well today as I climb under the truck to diagnose my transfer case to skit plate banging I notice that there is exhaust coming from around the flanges. There is light black by the flanges on the heads. Do these manifolds have gaskets???? It does not appear that they do. I need to pull the manifolds off so that I can seal them up. You thoughts are appreciated.
Old Nov 15, 2009 | 02:11 PM
69cj's Avatar
69cj
They do not come from the factory with gaskets and Ford does sale gaskets for them.
Old Nov 15, 2009 | 02:26 PM
Fully_Loaded
Next question is how much of a pain is it to swap the gaskets? It did not look bad but I know looks are sometimes deceiving
Old Nov 15, 2009 | 02:29 PM
69cj's Avatar
69cj
I personally have not had to do them but a few others here and on other sites have stated that they were able to change them thru the wheel wells.
Old Nov 15, 2009 | 02:35 PM
cheezit's Avatar
cheezit
huh? my cab alway smells like diesel... I so love that smell
Old Nov 15, 2009 | 04:05 PM
Fully_Loaded
LOL, I spend a lot of time in my truck and half burnt diesel fuel smell burns the eyes. It looks like I can get it done from under the truck. I will have to look closer.
Old Nov 15, 2009 | 05:48 PM
Bustaduck's Avatar
Bustaduck
post back mines leaking also need to fix it but scared I can't get the studs aloose
Old Nov 15, 2009 | 05:51 PM
cheezit's Avatar
cheezit
the real awnser is you can remove the bolts that hold the manifod to the head and loosen the Y-pipe bolts to the exhaust manifold and slide gaskets in. just do 1 side at a time.
also yes you will have to do some work from the inner fender well. pop those out first and you will see its not so bad.
Tomm
1983 - 2012 Ranger & B-Series
Jan 28, 2010 04:04 PM
sc00ter
Jun 12, 2007 09:24 PM
cujo8
Jan 11, 2007 07:09 AM
mr_muldoon
1997 - 2003 F150
Dec 30, 2005 08:29 AM
Argo
May 19, 2004 07:02 PM
