Guys I need help!
One problem with the ring issue is even with out compression rings the oil rings on a fast moving piston will have more than 0 psi of compression
Is there some glow plug tips stuck in the valve seats? starting fluid has been known to blow the ends of the glow plugs off.
as for the ATF, my cousin has a friend who works at a "national chain" trans shop and gets all of the flush fluid, he runs 75% ATF 25% diesel with no problems, and has been doing this for a long time.
the valve train seems to be working properly. still haven't seen under the driver side VC, but when cranking for the compression test you would think if there was a valve issue you would hear it while cranking. just a thought... i'm not going to say that the valves on the DS are any good. for all i know the other side may show 0 compression across the board.
We are safer with either than most are. we do wait for the GP's to cycle off before we give it a spray. not saying it helps too much but i imagine it helps a little to prevent blowing up too much stuff with it.
here is a question. these trucks take a lot to stay running so would just a small spray from an either can be enough juice to keep an engine going if it had barely any fuel trickling in the cylinders??????? Break out 2 cans and try it. haha. or break out the nitrous bottle........ JK!!!!!
unless the bore is completely trashed.
The compression test might have not had anything to do with the oil.
It could be heat/friction related.
You have access to a bore scope?
Bill
Bill
Could you explain why the exhaust valve would do this?????? i have never heard of that before..
If it just spins when you're squirting ether at it, I wouldn't know what to think!
Jim, I should have said, someone had previously worked on it, I'm guessing before he bought it. The fuel lines they used were just gas lines. They were infact swollen and deteriorating. Also, the guy was told by "an old diesel mechanic" that ATF would clean the injectors. So he proceeded to dump ATF in the fuel bowl spilling it all over everything in the valley, which is why all the weather pac connectors at the IPR were thrashed and wire loom was mushy at best. However, I didn't know diesel carried the same properties as ATF that would eat rubber, so I guess Travis' thought about eating injector orings is not correct. Duely noted, but I'm also not nieve enough to think this is the only guy to run ATF, so it would prolly be safe to say they would be okay.
Action, yes, I have several IPR's I can try. But my first encounter with the truck I pulled it and put new orings on it. Of course that's not to say it's not broken or non functioning inside. So I guess I should try that too. I had thought about it, but at that point in the night, I really didn't feel like pulling the fuel bowl again to go at it. So in my next installment with the truck, I will.
Heli, I'm pretty sure there are no glow plug tips stuck in the valves. At least for the passenger side. I pulled all glow plugs doing the compression test, and all had their tips. And the ATF at this point should no longer be an issue.
Steve, as far as the valvetrain on the passenger side, it's all working correct, I have to have the valve in the right position to get the compression tool on, so we had several "bump it" sessions to get them in the right position. But don't know on the drivers side.
heli, I may infact had flooded the engine with ether. I gave it a serious dose to the turbo, a few times. So that may be the case, slim, but maybe.
Bill, I agree.....it's zero, let's be done with it. But I just want it to run on 7 cylinders. And it does....for a few seconds. And I want to reitterate, and I'm not yelling at you bill, I just want everyone to make sure and read it.
WHEN IT DOES RUN, IT RUNS AS GOOD AS ANY MOTOR ON 7 CYLINDERS, FAILY SMOOTH WITH A MISS. SO IT WILL RUN, WE ARE JUST TRYING TO FIND OUT WHAT IS SHUTTING IT OFF.
Again, not yelling, just want to make sure we are all on the same page. LOL And yes Bill, TONS of blowby. Less with that injector on the dead hole unplugged.
Bill, I do have access to a bore scope, but do not own one. However, this borescope I have access to, will not fit in the injector nozzle hole, or glow plug hole. So I'm out of luck on the bore scope.
Bryan, yes it can emit white smoke when it's lean. Not sure what bearing that has here, but I do know this. You are in here trying to help us figure it out and I'm gratefull, thank you sir. And Welcome to FTE we are glad to have you aboard.
Bill, on the exhaust valve, are you thinking it's bent, or not seating correctly, but moving enough to provide varied results? This might be valid, because when it does crank, or is running, you can hear a pronounced "whoosh" on the compression stroke. But again, the compression on that one cylinder is not what's shutting it down....or if it is, I can't fathom how.
Cow, it would barely acknowledge that it had been invaded by ether. So yeah, it makes no sense. I'm going to stick with me flooding it on that front. You could run a plastic model engine on ether. LOL But like I said, when it runs, it runs fair.
Guys, all are great ideas, and I invite you to keep them coming. But with what we've discussed thus far, I'm still hesitant to either make him trailer it back, or travel the 60 miles to him and try it. He has to borrow truck and trailer, and I of course have less than zero time. But make no mistake, I will get back on this truck soon, so I will take all ideas with me on a list and go through them one by one.. Your help and info is ALWAYS greatly appeciated and I will keep pushing for a solution.
