starting problem
Old Nov 14, 2009 | 02:40 PM
docsludge's Avatar
docsludge
starting problem
So I have replaced my battery, the starter solenoid , and the ignition switch. I am able to jump across the starter solenoid and it fires right up with the key in the run position. It is also showing low voltage at the dash panel but once it is fired up it shows good voltage. The only things I havent replaced are the cables and the ignition lock cylinder. What Am I missing???
Old Nov 14, 2009 | 02:42 PM
docsludge's Avatar
docsludge
BTW the truck is a 94 f150 with a 351 and auto tranny
Old Nov 14, 2009 | 03:10 PM
subford's Avatar
subford
I take it when you say starter solenoid you are talking about the Starter Relay on the fender and not the starter solenoid down on the starter.
Take a look at your starter safety switch down on the drivers side of the transmission if it is an automatic transmission.
Old Nov 14, 2009 | 03:16 PM
docsludge's Avatar
docsludge
I do mean the starter relay not the solenoid, So should I just jumper the safety switch or does it need to be replaced and then checked. I have not gone out and looked at it yet.
Thanks
Dan
Old Nov 14, 2009 | 03:26 PM
subford's Avatar
subford
Do you have a E4OD or 4R70W transmission or a standard transmission?
Old Nov 14, 2009 | 03:30 PM
docsludge's Avatar
docsludge
It looks like an e4od but is it possible it could be a c-6, it resembles one I had in an earlier truck.
Old Nov 14, 2009 | 03:43 PM
brett12396f150's Avatar
brett12396f150
There should be a tag on the side somewhere that tells which it is.
Old Nov 14, 2009 | 03:52 PM
docsludge's Avatar
docsludge
Definitely an e4od, found tag on side, this is a new truck for me, still a little unfamilar with the truck. I long for the days when everything was simple and you didn't ahve to be an electrician to troubleshoot an ignition.
Old Nov 14, 2009 | 03:59 PM
subford's Avatar
subford
The start wire goes through the Manual Lever Position Sensor (MLPS) on the drivers side of the transmission.
If they were having problems with the transmission that could be the cause (a bad MLPS).
To test the MLPS use the below diagram:
Old Nov 14, 2009 | 05:01 PM
docsludge's Avatar
docsludge
is there a way to jumper this switch and test the ignition, and do you think that would also cause the low voltage showing on the dash. I keep thinking its some kind of bad ground but I can't find one.
Old Nov 14, 2009 | 09:12 PM
subford's Avatar
subford
No it would have nothing to do with low voltage on the dash.
You can jumper just about any safety device out. Just run a wire from the Ignition switch (or push button) and run it to where the small red wire with a blue stripe connects to the starter relay.
Nseal1996
25
Sep 19, 2014 06:26 AM
blackhawk21
1978 - 1996 Big Bronco
Aug 12, 2013 09:22 AM
vegatyme
Jun 25, 2008 11:14 AM
Jaxor78Ford
Dec 8, 2005 10:25 AM
yolbolsom
Mar 10, 2003 07:27 PM
