1978 - 1996 Big Bronco
Starter Issues
Old Aug 10, 2013 | 12:39 PM
blackhawk21's Avatar
blackhawk21
Starter Issues
Ever since I got my Bronco, it has had a wide array of issues. Now, it's something in the starter system. First, it was the solenoid its self. Then, after looking above the steering column, I found that the damn ignition switch had burnt up and the spring broke in it. Replaced all the wires connected to it, and it showed some life. Fired up not more than 20 minutes ago, and then, the ignition stuck and I ripped off the cable on the terminal. Tapped the starter solenoid 5 times, and now the ignition doesn't stick. Is the solenoid faulty or I have I done something wrong?
Old Aug 12, 2013 | 09:22 AM
Kemicalburns's Avatar
Kemicalburns
probably a faulty solenoid. get a motorcraft solenoid
jxnslotcar
23
Aug 18, 2020 02:53 PM
cranegrad
May 30, 2018 05:48 PM
Grupedog
Dec 29, 2017 09:55 PM
vinnyd62
Jun 2, 2015 10:08 PM
RVF150
Jun 26, 2012 03:09 PM
