6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
batteries dead
Old 11-12-2009, 09:37 PM
burrhead's Avatar
burrhead
burrhead is offline
batteries dead
well its always something,went to go to work, truck barely turns over maybe 20 times then just clicks, after setting a couple minutes, only clicks..had to go to work in the trusty FORD accord,, will check batts tomorrow, truck has 39000 and is about 2.5 yr old
Old 11-13-2009, 01:00 PM
Leonandlisa's Avatar
Leonandlisa
Leonandlisa is offline
I put a battery bug on mine so it tells me when they are loosing their charge so that doesnt happen to me. In the desert here two years is all you get out of a battery.
Old 11-14-2009, 06:24 AM
senix's Avatar
senix
senix is online now
Received 1,475 Likes on 1,053 Posts
interesting. 2.5 yrs old, what is your location? Hard winters or the heat? When I lived in Tucson, AZ you could only get a few years out of them.
I always check my terminals to ensure they are clean. Maybe taking the terminals loose and cleaning them is the issue?
Old 11-14-2009, 06:53 AM
ruschejj's Avatar
ruschejj
ruschejj is offline
Here is a thought, the engine block heater that you plug in for cold weather? Does it also charge the batteries? Would be nice if it did but I doubt it.
Old 11-14-2009, 06:56 AM
senix's Avatar
senix
senix is online now
good question..but it is not in the charging circuit. direct connection to the block.
anyone notice that FTE was basically offline yesterday? or was it just my pc's?
Old 11-14-2009, 07:52 AM
hanklin's Avatar
hanklin
hanklin is offline
Senix,,yes it was offline,,needed a fix,huh? lol
Ruschejj,, Senix is correct that plugging in has no connection to batterys however I just went through same scenario as you. Cold nights here and truck would not start in A.M but if I plugged in then it would. It dosnt require as much draw ( ? ) if the engine is warm. Maybe this will help till you load test and/or replace..If you replace do them both. I did yesterday
Old 11-14-2009, 08:34 PM
FivePointo's Avatar
FivePointo
FivePointo is offline
Bought my F350 11/07 I only tow our 5th wheel with this truck and the ocassional Home Depot trip. Truck has 6800 miles. I just had to replace mine when the weather got cold here in Georgia. (Cold as in in the 40's) I put 2 red top Optimas in it. Problem solved. However my previous 01 F250 batteries lasted 6 years.
Old 11-15-2009, 09:22 AM
69cj's Avatar
69cj
69cj is offline
Lack of use in some cases is worse than over use!
Old 11-16-2009, 09:33 PM
burrhead's Avatar
burrhead
burrhead is offline
I replaced both, with 850 cca exide, three year free replacement. Im about 30 ml. south of memphis tn. when i removed old ones they only read 10.65 volts, one had the red eye showing. luclely my son got a deal where he works,,75.00 each. I always keep the terminals clean, I called dealer, of course its over 36000 ml, soo soo sorry, My wifes expdition battery lasted almost 5 years.. oh well Im good for a least 3 years now, instead of 2.5
Old 11-17-2009, 10:19 AM
toolpush's Avatar
toolpush
toolpush is offline
Never heard of the battery bug, checked out the web site, looks cool, which model did you put on your truck? Will get one for mine.
Old 11-17-2009, 12:22 PM
koboss1's Avatar
koboss1
koboss1 is offline
i had the check engine light come on the other day and it was the cause of a bad battery took it to ford and they put a new one in after the tested it
Old 11-17-2009, 03:45 PM
hanklin's Avatar
hanklin
hanklin is offline
Koboss watch the other one, mine went out within 6 mos. of changing just the one. Logic would dictate that they service both but you know how that works
Old 11-17-2009, 04:53 PM
DanoFF50's Avatar
DanoFF50
DanoFF50 is offline
Former Vendor
Battery requirements are greater during winter months while their output is less, so proper battery care is an important part of equipment maintenance. Fluid Film will effectively stop any corrosion from occurring, allowing batteries to perform at optimum expenditure during this period. Fluid Film will keep battery terminals protected for a minimum of twelve months.
If you've never tried Fluid Film and live in the US, just PM me your contact info and I'll ship out a sample can for free. That is how confident we are in our product.
Old 11-17-2009, 07:43 PM
koboss1's Avatar
koboss1
koboss1 is offline
i always like to change them both 2, but am at the mercy of the warranty, but i hear you
thanks
koboss
Old 11-20-2009, 11:26 AM
71stang99's Avatar
71stang99
71stang99 is offline
Temporarily Deactivated
We are in the Las Vegas area and oddly enough our 04 F150 had the original motocraft battery in it when we traded it in for the new truck last month. I was really surprised it lasted that long even after it was ran dead twice due to a faulty brake light switch.
Quick Reply: batteries dead
