Another Dead '06
Old Nov 11, 2009 | 02:03 PM
VelocityDriver's Avatar
VelocityDriver
Another Dead '06
Just 41K miles, had the heads, egr, oil cooler, rear seal done last year... This morning after changing the oil & the fuel filters no start. Cranks and sputters for a few seconds and dies. Fuel in the upper, good oil pressure when cranking...
Throws the DTC's: P0600 & P1000 (Changed out batteries also), the P2614 Cam Sensor and P2617 Crank Sensor.
Dealer sending a flatbed but they are on a 2 week back log in diesel service.
Old Nov 11, 2009 | 02:45 PM
texans's Avatar
texans
Did you use factory filters? Other brands are known to cause problems
Old Nov 11, 2009 | 04:43 PM
VelocityDriver
Use Racor except for today, couldn't get them today and had to use NAPA Gold, didn't matter the truck wouldn't start with the old or new filters.
Old Nov 11, 2009 | 08:06 PM
Lou Braun's Avatar
Lou Braun
Try charging your batteries so that they have a full charge before you try the next start.
It is possible that low battery voltage is causing the no start condition. Been there, done that.
Lou Braun.
Old Nov 11, 2009 | 09:00 PM
bismic's Avatar
bismic
Not sure I understand. You said the "no start" began after the oil and filter change. How did you verify the "no start" w/ both the Racor and Napa filters?
If the problem began immediately after the oil and fuel filter changes, it seems that these filters would be the place to first suspect.
Old Nov 11, 2009 | 09:15 PM
98SurplusExpy's Avatar
98SurplusExpy
My guess? You blew the STC fittings on the High Pressure Oil line and/or the truck is not building high oil pressure for some other reason.
Just a guess doh ...
Old Nov 11, 2009 | 09:43 PM
VelocityDriver
Went to start the truck in the morning to let it warm up before the oil change. Truck cranked but did't fire (popped 1-2 seconds and died). I had already determined that one of the batteries was going south and decided to to replace it. Replaced the battery and still did't run. Put the older battery on the charger while getting fuel filters (1 1/2 hrs later ). Got home and checked battery votage 13.4v & 13.2v with key off, with both connected and key on was getting a 12.4v while in the start mode, getting 11.6v while cranking. Tried cranking still nothing, thought the fuel filter was clogged and replace them, still no fire. Changed the oil to see if anything "unusual" was in the oil, nothing. Also reset the computer by disconecting the batteries and checking all the relays and fuses, they all checked good.
Old Nov 11, 2009 | 09:46 PM
VelocityDriver
Would that cause oil dripping down the rear of the passenger side head onto the starter? I've had the truck in 2 times for an oil leak that they can never find where it coming from, but that's another story in itself...
Old Nov 11, 2009 | 09:52 PM
bismic's Avatar
bismic
You will not see an oil leak w/ a bad STC fitting. It is an internal leak.
The bad batteries are a possible clue. Whenever one is bad, you need to change them both. To make sure the batteries are good, load check them individually (when disconnected).
Bad batteries often lead to a failed FICM (Fuel Injection Control Module). A bad FICM will cause a no-start condition.
Old Nov 20, 2009 | 07:31 PM
VelocityDriver
Truck is back... New FICM, EGR Valve, software upgrade to computer, and CAC tube. Seems to have more boost (35#)and runs a little better. All the paperwork stated was software upgrade to latest version.
Old Nov 20, 2009 | 08:18 PM
bismic's Avatar
bismic
Interesting - how did you make out on the warranty covering the cost?
BTW - the boost seems too high to me.
Old Nov 20, 2009 | 09:39 PM
FordMan35's Avatar
FordMan35
35# of boost seems high to me to. I rarely ever see my boost go much past 20#.
Old Nov 21, 2009 | 03:31 AM
VelocityDriver
$0. I was surprised I had the cc out ready to pay the $100 but they said it was covered under bumper to bumper.
I will recheck boost again when I drive it today. But I am getting more than I was before.
Old Nov 21, 2009 | 06:56 AM
bismic's Avatar
bismic
, Great to see a dealership do the right thing on the warranty!
Old Nov 21, 2009 | 09:34 AM
69cj's Avatar
69cj
I agree with above. 35 lbs. is way high for a stocker. I have never seen more than 27 to 28 and that's pulling a 31 foot 5er.
