Number Dummy Help
Old Nov 11, 2009 | 11:19 AM
Ztalon's Avatar
Ztalon
4wd Low
Number Dummy Help
ND,
can you help me with locating spindle seals for a 1966 F-100 4x4, P/N C6TZ-3171-A. Or possibly if superceded, what the new number is. I have two of the original seals and they are superior to the aftermarket ones available and would like to acquire two more.
Thanks for any help you can give m
Old Nov 11, 2009 | 12:25 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Ztalon
ND,
C6TZ3171B .. Spindle Pin Bearing Grease Seal / Obsolete
C6TZ3171B replaced C6TZ3171A (A & B = The seal is exactly the same).
Ford changed the part numbers suffix from A to B, due to a packaging change.
How many would you like?
C6TZ3171B =
SHOWALTER MOTOR CO. in Vernal UT has 2 = 435-789-3818.
MILLER OBSOLETE PARTS in Binghamton NY has 2 = 800-546-7278.
TEAM FORD L/M in Silver City NM has 4 = 575-388-1818.
KINSEL L/M in Beaumont TX has 8 = 800-816-2894.
PARTS INTERNATIONAL in Farmers Branch TX has 11 = 888-727-0418.
GREEN SALES CO. in Cincinnati OH has 41 = 800-543-4959.
C6TZ3171A =
GRIESEL MOTOR CO. in Okarche OK has 2 = 405-263-7242.
BURNWORTH-ZOLLARS FORD L/M in Ligonier IN has 2 = 260-894-7176.
KOVATCH FORD in Nesquehoning PA has 2 = 570-669-5118.
DOTTS MOTOR CO. in Clearfield PA has 7 = 814-765-9681.
Note: When typing Ford part numbers into online websites, REMOVE any spaces or hyphens. Type the numbers as I did.
If spaces or hyphens are used, you'll get the message: No parts found.
Old Nov 11, 2009 | 12:46 PM
Ztalon's Avatar
Ztalon
4wd Low
Thank You ND...........your reply was extremely helpful
Thanks again!
