Ac is shot
Old Nov 11, 2009 | 01:38 AM
andyman91's Avatar
andyman91
Talking Ac is shot
I am going to be putting on a new ac clutch and was wondering what i should do and if it is hard or not.
Old Nov 11, 2009 | 06:16 AM
subford's Avatar
subford
No it is not hard.
What is it on?
Old Nov 11, 2009 | 08:24 AM
rla2005's Avatar
rla2005
Next question is why you think the clutch is bad? A bad compressor can put too much strain on the clutch which in turn makes the smoke come out. Does the compressor run long enough to check the pressures?
Old Nov 11, 2009 | 09:16 AM
breisr's Avatar
breisr
i am my no means a mechanic and i changed on on my 93 302. it's not that hard. if i recall, their are spacers you have to put behind the clutch. (tiny washers)
Old Nov 11, 2009 | 02:43 PM
andyman91's Avatar
andyman91
Its a 1989 ford f150 xlt lariat thanks for the help i havent tried to check the pressure what are the signs its bad.
Old Nov 11, 2009 | 03:29 PM
rla2005's Avatar
rla2005
Fluctuating pressure, normal head pressure/high suction, audible noise from the compressor are some common signs something is amiss. I have seen many cases where replacing a clutch resulted in another fried clutch because something was wrong with the compressor.
