Dealer service ???
Old Nov 10, 2009 | 08:17 PM
High Intentions's Avatar
High Intentions
Mod Specialist ;)
Dealer service ???
Will letting the dealer read my computer to see whats wrong with my backup sensors mess with my DP tuner???
Old Nov 10, 2009 | 08:22 PM
megawatt00's Avatar
megawatt00
Just scanning the codes no. If they reflash the PCM yes. I wonder if AE can do the same scan.
Old Nov 10, 2009 | 08:26 PM
farmdad's Avatar
farmdad
Yep. I have read the codes on an Excursion and my pickup and both came up with backup sensors bad. It even told exactly which ones. I was impressed.
High Intentions
Mod Specialist ;)
Whats AE??
Old Nov 10, 2009 | 08:33 PM
big poppa's Avatar
big poppa
Here yaa go. Riffraff Diesel: Total Ford Enhanced Bundle
Old Nov 10, 2009 | 08:37 PM
megawatt00's Avatar
megawatt00
Good to know Mark. I have to "play" around with mine just to see what it can do.
Anyone in PA have one to help the brother stay away from the stealership?
Old Nov 10, 2009 | 08:47 PM
High Intentions
Mod Specialist ;)
Would a canobd2 scan tool do it?
Old Nov 10, 2009 | 09:03 PM
megawatt00's Avatar
megawatt00
No our trucks are not OBDII compliant so that type of reader won't work.
Old Nov 10, 2009 | 10:10 PM
big poppa's Avatar
big poppa
Would like to help out a fellow Pa'er out Jim but all I got is the SC code reader..
Old Nov 10, 2009 | 10:19 PM
bigb56's Avatar
bigb56
One thing you might check is the Park Aid module. It is located way up high behind the passenger kick panel. If any moisture gets in thru the cowl (very common) it drips right on the module connector and runs inside along the board and ruins it. A new module will come with the short harness and connector to replace the corroded one. When I replaced mine I slid it inside a ziplock bag with the opening pointing down, you can still hear the speaker fine thru the ziplock bag.
Old Nov 11, 2009 | 04:37 AM
High Intentions
Mod Specialist ;)
On the excursion its in the passenger side rear of the truck. I have a new one and still no change.
Old Nov 11, 2009 | 07:34 AM
farmdad's Avatar
farmdad
From what I have read, the sensors can go bad or a connection disconnects or is corroded. Guess I would start there to eliminate those possibilities.
I was going to get some test values for you from my service manual but there are a lot of steps to go through to test the system. If you want, I could try to PM you the pages. Let me know.
Old Nov 11, 2009 | 12:42 PM
High Intentions
Mod Specialist ;)
If it's not to much trouble for you to do that. It couldn't hurt to try.
Thanks Mark
