6 volt to 12 volt.
I've recently purchased a 51 F1 and I am looking to convert the 6 volt system to 12. It is all stock under the hood (239 flathead) and I am tired of the sluggish starting and dim lights. I've been looking around the net to see if there is a kit with all items needed to do the conversion, but I am having no luck (found chevy kits all over the place). Guess what I am looking for is a link if any knows of a site or if anyone knows everything that will be needed to change over the system, I'm guessing the simple stuff like generator over to an alt, gauge cluster (or adding a resistor to drop the voltage back to 6), coil, lamps/bulbs, etc. I've read the starter does not need to be changed will work fine on the 12v system.
-Thanks for the help
Willie
Gil
Julu Gurie here! tee hee!
Yep this comes up once a week about so we have lots of background and threads for the conversion.
It really is a very simple process if you do some moderate preplanning, familiarize yourself with your truck, know what youwant to support electrically, and just connect one wire at a time - that's all!
As mentioned, I have a gallery with some Power Point drawings of switches, and signal flow for the three electrical subsystems you will want to group - engine, lights, and accessories. Take a look at those and when you know what kind of set up you would like, write me an e-mail (include your real e-mail address) and I will send you the ones that are applicable and even modify them for your needs. That way youcan enlarge or modify them for your needs. They are pretty straight forward.
I have saved links for wiring and problem solving on just about everything you could imagine.
So just to start, here are a few things to think about:
1) Do you want a prefabricated/manufactured wiring harness, or do you want to wire one strand at a time yourself. I prefer to wire one strand at a time. That elliminates getting cross wired or depending on vendors to buld the harness to fit your needs. But the "EZ wiring harness" is very highly thought of here as well.
2) I would definately recommend you go with a one wire type altrnator - either GM or after market. This elliminates the external voltage regulator and is a much cleaner and dependable set up. An alternator rated at 75 amps will be more than sufficient. I have links for that installation as well.
3) Decide what extra electrical items you would like on the truck (ie spotlights, stereo, electric fuel pump, electric fans, etc)
4) Here are the items that MUST be REPLACED for the conversion: Generator/regulator; light bulbs; power distribution point (in the 51 it's two circuit breakers so you will have to bypass those and use fuse blocks); points, condenser, coil; radio; cigarette lighter; battery; Starter solenoid; and headlight switch. The current headlight switch will work ok except for the dimmer on the instriment panel/speedometer lights. I you want to keep the stock switch, that's ok, you just can't dim the instrument lights.
These items will work if you install voltage reducers or adapters such as the little reducers for the gauges or vol-ta-drop voltage reducers for the accessories: Gauges; heater, wipers. I have pictures and installation threads for all of these.
The starter need not be changed, but you have to be careful not to roll it for too long (like 10 seconds). Likewise, the ignition switch; starter button; and, high beam switch can all stay. If you have signal lights, the signal switch can stay (but you have to change the little bulbs in it if equiped).
If you do not have signal lights and want to install some, you will need to change out the light sockets on your running (tail) lights and marker (parking) lights on the front - plus wire in a signal switch - simple. I have the diagram for the install.
Well, that's about all I can think of for now. Just remember this about your new electrical system. If you take the time and don't shortcut, your electrical system will be worry free, easy to maintain and add on to. But if you short cut, I promise it will be the one item that every day makes your truck a miserable piece of garbage from hell that you will hate to drive and work on. So, take your time and do it right- NO used replacement components or wire! I'll be glad to help where ever I can
Remember the 7 P's...."Poor Prior Planning Provides **** Poor Products" Do the planning and the install will be a breeze!
On the other hand, 12 volts is often preferred simply because of the convenience when dealing with replacement parts, e.g. lights, etc. Me, I haven't seen the need yet but ya never know...
I'd start a new thread to introduce yourself to everyone (and so you can post pictures of your truck)!
The point about the battery cables is a good one. If you "lean" on your 6 volt started for a few seconds too long with the smaller cables, you will no doubt either fry the cables or the starter. A 6 Volt accessory requires TWICE the amperage to produce the same amount of work as the same accessory in 12 volt.
And not to be contradictory to a newbie right off the bat, I will however provide this statement from "Battery Low in Charge" troubleshooting procedure in the 1949-1951 Frod Truck Shop Manual - Page 351, as food for thought - quote:
End quote!
Bad owner, BAD!
And don't even think about putting an electric fuel pump (about the same as driving with the lights on all the time) on the truck.
In case you didn't read it between the lines, what this means is that the 6 volt battery and charging system originally installed on these trucks is SO MARGINAL, that if your motor oil is too thick, or you have to run the defroster or drive with the lights on for any length of time you are going to run down the battery....could get a dead battery!
Car manufacturers went through the significant expense and change to upgrade to 12 volt electrical systems in 1956. There's a reason - this is it.
Another reason for the OEM 12 volt change was increased compression ratios and larger engines beginning to be built in the mid fifties, putting even more strain on starting and charging systems. Electric accessories like power windows, seats, and air conditioning were beginning to be seen on the option lists more prevelently, and as noted, the old 6V systems could barely keep up with what they had been doing.
Fact is I've been on the fence about switching to 12V myself in the case of this rig. My Model T's can stick with 6 volts however.
Another advantage for the car companies has been hinted at, but you could get by with about half the copper in your car. A few years ago there was a lot of talk about the car companies going to 24V or higher for the same reason.
Hence...
I never get tired of reading 6 to 12 v threads
