Name this Transfer case (pic)
Old Nov 10, 2009 | 03:57 PM
Csteptoe's Avatar
Csteptoe
93 f150, 351 with a C6, no transfer case shifter installed and trying to get 4wd working. In the second pic is that where the shift linkage goes? Thanks
Got the truck as-is with not much info about it.
No there is not a front drive shaft
Old Nov 10, 2009 | 04:28 PM
Eddiec1564's Avatar
Eddiec1564
In the 1st photo you see the round lable? That has all the info on what xfer case you have.
But any way it looks like a NP208 hanging there. Being a 93 truck it most likely not the original xfercase. Most 90's trucks had Borg Warner tcases under them.
Ok, after reading your other post, This New Process NP208 xfer case is only a manual shift. you will need to find a shift assy and get it installed.
The Np208 case I have seen are little stronger than the electronic shift BW13?? xfer cases(seen 3 of the BW's shatter before the guy put a NP208 in). And you don't have to worry about the electonics crappping out when you need 4x4. Also check to make sure you have manual lock out hubs, you could use the auto locking hubs(most likely installed with electronic shift) but you will not be able to shift on the fly with a manual Tcase!!
Old Nov 10, 2009 | 05:03 PM
Csteptoe's Avatar
Csteptoe
Thanks alot for the info, yes the motor351W,trannyC6, and TC where changed in this truck. It does have manual locking hubs.
Do you know where i might start looking for the shifting assembly? Thanks alot
