68 with a 76 axle help
Old Nov 10, 2009 | 05:27 AM
68f250guy's Avatar
68f250guy
okay just acquired a front axle from a 76 and it is incomplete
i have from the spindle on drivers side to axle shaft on pass. side what all years hubs steering knuckles draglinks disk brakes will work?
will anything off my 68 axle work?
thanks guys!!!
hey if anyone has any idea where to ofind these parts feel free to let me know
Old Nov 10, 2009 | 11:50 AM
jowilker's Avatar
jowilker
4wd or 2wd??
John
Old Nov 10, 2009 | 02:26 PM
68f250guy's Avatar
68f250guy
it is a 4x4 closed knuckle original and bought a 76 open knuckle
Old Nov 10, 2009 | 06:40 PM
Ford6.02005's Avatar
Ford6.02005
thanks guys!!!
First you need to identify the axles using the Spicer Bill of Material #. The 1976 axle is kind of a rarity since it was only used in 1976 -1977.5 models.No parts from the 1968 axle will interchange except possibly some of the differential/ring & pinion parts!Look for BOM# on tag attached to front cover or stamped into long side axle tube facing forward. Many of the parts have been discontinued but used parts are still available.
Old Nov 11, 2009 | 09:08 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
First year for front disc brakes on F100/250 4WD's: 1976.
The Ford ID code tag is under one of the bolts that holds the inspection cover on. Do not be surprised if it's missing.
There may be a seven or eight digit Dana ID number (like: 603010-1 or 603010-11) stamped on the axle tube.
Dana 60 front/rear axles: Beginning in 1973, there is a 2" x 1/2" Dana ID tag bolted to the housing just adjacent to the inspection cover.
This tag has either the seven or eight Dana ID number stamped on it.
If you find the Ford ID code and/or the Dana ID number, post what they are, I can decode them...tell you what axle you have.
Old Nov 11, 2009 | 08:45 PM
68f250guy's Avatar
68f250guy
has anyone else used other year parts on these axles other than early 77?
even draglinks and such?
i have a few yards around but no 76 or early 77 just late 70's 80's stuff so any info would be great
Old Nov 11, 2009 | 08:58 PM
NumberDummy
has anyone else used other year parts on these axles other than early 77? Even draglinks and such?
Looking up front driving axle parts in the 1973/79 Ford truck parts catalog is a major undertaking without an axle ID code.
I wouldn't even attempt it, as there are literally 100's of different "Front Driving Axle" parts lists.
Without the tag, it's a guessing game as to which parts list is the correct one.
With Ford, not only are all the front driving axle parts listed, but so are the brake rotors, seals and most of the suspension parts.
So...without the ID tag code, I cannot tell you what other parts from other years (if any) are the same.
Old Nov 12, 2009 | 05:46 AM
68f250guy's Avatar
68f250guy
cool ill get the tag off the axle today and let ya know thanks!!
Old Nov 12, 2009 | 06:05 AM
68f250guy's Avatar
68f250guy
these are the only numbers i saw
looking at diff from front lower left 44 8cf and the upper right 35133
i think there was a number 3 in lower right as well
thats it i think
Old Nov 12, 2009 | 05:20 PM
Ford6.02005
thats it i think
Unfortunately those numbers are "generic" to all D44 axles... You need to find the Spicer BOM# to find specifics about type of differential, axle lengths, wheel end details,etc. Usually it is found within about 12" of center casting on passenger side axle tube facing front. To find steering linkage info you might be better off trying a Moog or McQuay-Norris catalog to see if any parts interchange.
Old Nov 14, 2009 | 03:11 PM
68f250guy's Avatar
68f250guy
got my front axle code!!!
the code is
4 09 d6ta aad
603762 1
thanks for the help on what all parts will work off other years including mine!!
Old Nov 14, 2009 | 05:20 PM
Ford6.02005
the code is
4 09 d6ta aad
603762 1
BOM#603762-1 shows 1976.5 F-250 Dana 44, 4.09 ratio,open differential. Disc brake open knuckle with external lockouts. Like I mentioned in a previous post this axle was used in 1976 thru 1977.5 Highboys only. This axle was used up till the last Highboy was produced. All parts in the differential interchange with most D44 low pinion axles.This axle used the "long" outer stub axle specific to these models only! Should not have a problem finding used parts... I still see them in salvage yards up here in MN.
Old Nov 14, 2009 | 05:45 PM
68f250guy's Avatar
68f250guy
thanks for the decode
im glad you see alot where you are parts are scarce here in eastern ohio.....
btw if anyone can lead me in the direction of the parts i listed earlier please let me know it is greatly appreciated
Old Nov 15, 2009 | 05:22 AM
NumberDummy
D6TA-AAD / 1973/79 Ford Light Truck Parts Catalog / Front Driving Axle Parts List # 30.5J
D6TZ3304A .. Draglink / Obsolete / Fits: 1976 F250 4WD, 1977 F250 4WD before 4/1/1977.
GREEN SALES CO. in Cincinnati OH has 9 = 800-543-4959.
D3TZ3A131B .. Left Tie Rod End / Obsolete / Fits: 1973/77 F250 4WD (High Boy).
GREEN SALES CO. has 7.
D3TZ3280B .. Right Tie Rod Assy. / Obsolete / Fits: 1973/77 F250 4WD (High Boy).
GREEN SALES CO. has 28.
The last High Boy (1977 F250 4WD) was assembled before serial number Y20,001.
Green Sales Co. (greensalescompany.com) is the largest Ford obsolete parts source in the world.
Old Nov 22, 2009 | 04:31 PM
68f250guy's Avatar
68f250guy
thanks for the help guys picked up my 77 axle today woohoo!!
didnt think 200 was bad for a complete assembly if anyone needs the ram assist stuff off it im not putting it on will let it go reasonably and i have a 76 axle incomplete outer axle ends on it everything is there from the knuckles in and i have caliper brackets too let me know
