Sponsored by: Real Truck
fuel miss? help!
Old Nov 9, 2009 | 10:05 PM
cbonen's Avatar
cbonen
Cool fuel miss? help!
Just bought a 02 f250 4x4 v10 208k miles slight miss at idle rough shaking miss at 60mph 1500rpm stalls at stop lights sometimes and hard 2 get moving again, rev and slam in gear. Scanned and found no miss codes plugs are white ,changed fuel filter, was plugged, added 2 cans of sea foam helped stalling but still has a mean miss. only codes r output speed sensor malfumction and intermittent vehicle speed. cleaned mass air , any ideas wat 2 do next?
Old Nov 9, 2009 | 11:04 PM
Robs06SuperDuty's Avatar
Robs06SuperDuty
sounds like a Coil Pack taking a dump. change COP's and plugs...
Old Nov 9, 2009 | 11:17 PM
ALASKAN 13B's Avatar
ALASKAN 13B
I would perform a cylinder balnce test. You can unplug individual injuctors or coils to find cylinder thats missing. The ones with no change are the problem cylinders. Injectors are probubly plugged if filter was plugged.
Old Nov 10, 2009 | 12:15 AM
wallz's Avatar
wallz
Take a spray bottle with a little vinegar and water mix in it and spray around the cops and boots while engine running. Then check again for codes. Sometimes when a cop is about to go they don't output a code. The water will help it along. After that you will probably want to look at all the rest of the boots, or even just replace them.
Old Nov 10, 2009 | 06:14 PM
cbonen's Avatar
cbonen
work in progress
thanks 4 the info guys will try these options 2 maro
Old Nov 10, 2009 | 06:18 PM
cbonen's Avatar
cbonen
my y pipe and exhaust is shot. Shud i buy a factory or after market system? iz there any performance gain?
Old Nov 10, 2009 | 06:34 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
If you're going to spend the money, go aftermarket. Newer, stronger pipes and freer flowing muffler sounds better than the stock, restrictive system.
Old Nov 10, 2009 | 07:43 PM
redford's Avatar
redford
A lot of owners have used this Y-pipe with good results.
00-04 Ford F250-F350 6.8L V10 Gas Saving Y Pipe :eBay Motors (item 220505732670 end time Nov-14-09 14:14:26 PST)
Old Nov 11, 2009 | 05:39 PM
cbonen's Avatar
cbonen
problem solved
spray bottle trick worked. Cyl 7 misfire , replaced coil and plug runs good think i mite even spring for 9 more new plugs, Nice! as for exhaust maintenance u guys think a aftermarket system would too loud? i live in northern MI and plow 38 driveways at 3AM at least they would know i showed up
Old Nov 11, 2009 | 07:20 PM
redford's Avatar
redford
Get a new Y-pipe, then use a stock muffler.
Old Nov 16, 2009 | 08:06 PM
cbonen's Avatar
cbonen
any body ever have their steering box bolts break off ? YIKES
Old Nov 16, 2009 | 11:49 PM
redford's Avatar
redford
Maybe you should start a new thread on that subject.
