Oil gauge fix
Old Nov 9, 2009 | 08:21 PM
Eddiec1564's Avatar
Eddiec1564
Oil gauge fix
Here's some info about fixing the oil gauge to be a real gauge and not a idiot gauge!
Ford Oil Pressure Gauge Fix
Old Nov 9, 2009 | 08:31 PM
quicklook2's Avatar
quicklook2
i think fte has a how to do it in the tech section.
Old Nov 9, 2009 | 08:45 PM
DBGrif91's Avatar
DBGrif91
I lost interest after reading this fix doesn't work for 90's model pickups. Otherwise it was useful up to that point...
Old Nov 10, 2009 | 05:00 AM
EPNCSU2006's Avatar
EPNCSU2006
DBGrif, you could check the back of the cluster and if the resistor is visible, this fix should still be valid.
Old Nov 10, 2009 | 09:12 AM
DBGrif91's Avatar
DBGrif91
Thanks for the tip- I suppose I can do that when I get the chance to work on my truck again- we recently moved and it's just been one thing after the other- the old pick 'em up truck has had to wait for a few things.
Old Nov 10, 2009 | 02:47 PM
lmd91343's Avatar
lmd91343
It's easy. Even I could do it!
I bought an instrument bucket with a tach to replace my non-tach bucket. The bucket did not have a resistor on the board. I think it was from an '87. I popped it in my '89 and the gauge displayed max pressure. As soon as I put in a pressure sender from an '87 it worked like a regular pressure gauge.
I think the cutover was between '87 and '88. The '87 bucket had no resistor, My '89 did and so did a '91 bucket I bought. The pressure sender I bought for an '87 is full range. My '89 is only on/off.
Old Nov 10, 2009 | 04:04 PM
Eddiec1564's Avatar
Eddiec1564
I know on a 94 F150 that resistor is there. I just swapped a 94 cluster with tach in to my 95 E350 bus, I wired it up so I can short out that resistor without taking the cluster back out. With it shorted, the guage will read high like Imd91343 said. I think 97 is when they changed things again and that resistor mod won't work?????
Toplait
Apr 17, 2014 10:56 AM
shawbran
May 31, 2011 09:39 PM
rebel_ford4x4
24
Oct 23, 2004 09:26 AM
jayharrison
2004 - 2008 F150
Apr 18, 2004 12:24 AM
PigFarmer
Jan 2, 2003 07:15 PM
