auto trans issue - code P0756
Old Nov 9, 2009 | 05:49 PM
MYWEIGH's Avatar
MYWEIGH
Question auto trans issue - code P0756
i have a "p0756" error code = shift solinod "B" stuck open. can't find were in the tranmisson that solinod is located ford does'nt either. any ideas
Old Nov 10, 2009 | 06:16 AM
Maxium4x4's Avatar
Maxium4x4
Item Part Number Description
1 7C155 Solenoid body-to-case gasket
2 — Ditch plate
3 7H038 Backing plate gasket
4 — Backing plate
5 W300512 Backing plate-to-manifold bolts
6 W500100-S300 Backing plate-to-case bolts
7 N805326-S Solenoid-to-case bolts
8 — Manifold body
9 7D376 Manual valve
10 7J136 Low reverse clutch solenoid SSPC-E
11 7J136 Direct clutch solenoid SSPC-D
12 7J136 Intermediate clutch solenoid SSPC-C
13 7J136 Coast clutch solenoid SSPC-A
14 W708500-S300 Solenoid-to-case bolt
15 7J136 Overdrive clutch solenoid SSPC-B
16 — Line pressure relief valve
17 7J136 Torque converter clutch solenoid TCC
18 7G383 Line pressure control solenoid PC-A
19 7E335 Pressure switch retaining clip (W)
20 — Wiring harness retaining bolt
21 7G276 Wiring harness
22 7H141 Transmission fluid temperature (TFT) sensor
23 — Direct clutch bore plug
Old Nov 10, 2009 | 04:05 PM
MYWEIGH's Avatar
MYWEIGH
thanks - some information i can finally use. is a safe bet that it would be #15 if the code = "b" stuck open ?
Old Nov 10, 2009 | 04:37 PM
69cj's Avatar
69cj
That would be my deduction if you care to hear it.
Old Nov 10, 2009 | 05:50 PM
MYWEIGH's Avatar
MYWEIGH
i thank you for your time with a problem i'm dealing with and i wouldn't ask for our assistance and not want to hear about it.
thank you.
moejr
Electrical Systems/Wiring
Dec 5, 2016 09:58 AM
miked_939
Apr 11, 2015 11:38 AM
78fordman
Feb 24, 2014 07:27 AM
HD RULES
Aug 19, 2010 01:44 PM
karageorge2
Jan 30, 2008 11:36 AM
