good programmer for 97 stroker?
Old Apr 30, 2010 | 01:31 PM
  #61
Brown Falcon's Avatar
Brown Falcon
Unless you really need some grunt for heavy towing or offroad I think that 4.10's would be adequate for 37's. Lots of guys running them here.
I'm doing ok with 3.55's and 33's, but I want to run 35's in the future and thinking about 4.10's or 3.73's if I can get a good deal on them.
Old Apr 30, 2010 | 01:47 PM
  #62
Talyn's Avatar
Talyn
With the 2 spider setup and 3.55's of the 10.25 stearling, you'll eat up spiders.
Go with the 4.10's or 4.33's with the 37's to keep things easier on your spider gears.
That or switch to the 10.5 gen 3 setup with the 3 spider gears.
Old May 1, 2010 | 09:06 AM
  #63
Brown Falcon
Will the 10.5 internals swap into a 10.25?
I know the limited slips bolt right in... wasn't sure on the gears and other internals.
Old May 1, 2010 | 10:08 AM
  #64
Talyn's Avatar
Talyn
Far as I know, you can.
You can just pull the whole carrier and pop it into a gen 2 or 1.
The pinions are different though on the gen 3's.
You can upgrade a gen 1 to a gen 2 with a gen 2 pinion.
Gen 2's have better bearings on the pinions, but the better carrier and disk brakes on the outside are on gen 3's.
Old May 1, 2010 | 11:27 AM
  #65
Brown Falcon
Interesting. I'm looking for a wrecked Superduty to steal a limited slip from. If it has 3.73 gears I might grab those too.
Old May 1, 2010 | 02:51 PM
  #66
BadDogPSD's Avatar
BadDogPSD
From what I've been told, the SD gears will not work in the 10.25 housing.
The SD carrier assembly slips right in. I put a 10.5 LS unit in my truck, but used 4.10's for a 10.25.
Old May 2, 2010 | 08:11 PM
  #67
Brown Falcon
Did you have to get it shimmed or anything to put the 10.5 carrier in?
Old Dec 14, 2010 | 04:21 PM
  #68
Big red_11's Avatar
Big red_11
Finally got a chip for big red, girlfriend made my decision for me, bought the ts performance 6 position and its unreal! like u guys said its as easy as pluggin it in and gettin on the road. 75hp mode seems to be the best all around setting. lots of fun thanx for the help fellas.
Old Dec 14, 2010 | 07:10 PM
  #69
Brown Falcon
Now save up for some good custom tunes. The TS tunes are ok, the tunes from PHP, TW, and DP Tuner are even better.
97 F150 Hootman
1997 - 2003 F150
Oct 16, 2010 04:08 PM
Kelly MT
Jul 4, 2009 06:58 PM
97powerstrokeman
May 17, 2009 09:46 AM
jlouki01
Mar 15, 2006 08:04 PM
97powerstroke
General Automotive Discussion
Apr 3, 2005 09:24 PM
