misfire #5 question
Old Nov 8, 2009 | 09:00 PM
donaldm's Avatar
donaldm
misfire #5 question
I have a 2005 f150 5.4 45,000 miles with an intermitent misfire on #5 (more sever under load) at 45k mile I wouldn't expect to need plugs or wires. Is there a common problem with the 5.4 on cylinder 5?
Old Nov 8, 2009 | 09:13 PM
bridge's Avatar
bridge
Sick 'n Tired
Watch out for your Cats man...you might have a stuck injector. If you're getting a misfire and hesitation (and can really hear popping) under load there's trouble abrewin'. Get to a dealer and pull some codes. Your cats are covered up to 80K miles.
Old Nov 9, 2009 | 01:55 AM
SMok's Avatar
SMok
Probably just a coil. Week coil's get worse under load and higher rpm's. Switch your #5 and #6 coil and see if the miss goes to 6.
Old Nov 9, 2009 | 08:57 AM
donaldm's Avatar
donaldm
good idea ill try it thanks
Went724
Sep 10, 2014 05:53 AM
sherry0331
Feb 11, 2014 07:24 PM
twelker_04
1997 - 2003 F150
Dec 15, 2009 08:26 PM
strokin72
Feb 28, 2006 04:41 PM
nallen731
Modular V8 (4.6L, 5.4L)
13
Oct 16, 2005 12:49 PM
