after changing my brake pads on my 2006 f250 i have noticed that when i push the brake pedal to the floor it feels very week when i push it in all the way, do these have to be bled or the pressure relieved some how after changing the pads? ?............i just forced the caliper open with a large pair of channel locks and installed the new pads , did i do something wrong here? thanks for any info on this....
A few items here;
1. When compressing calipers on a vehicle with ABS, it is best to open the bleed valve so as not to push crap back into the ABS system. I have done it your way without problems but it is not recommended.
2. The pads do need to be broke in per say. Do a series of stops from 25 mph, letting them cool off in between. Then kick it up to 40 to 50 mph and repeat. This is to get them seated without overheating.
3. It is time to flush your brake system. Preferrably every 2 years. I use the Prestone Dot 3 synthetic with good results. It is supposed to wick less moisture from the air. Stated on bottle, can't verify.
A few items here;
+1 but I use a different brake fluid.
What pads did you install?
69cj should have you fixed up. Please let us know if it gets better after the series of stops. If you do not flush the fluid, I would at least bleed the brakes (but it is a really good idea to do the flush - I am at the same point and will be doing it soon).
Also - IMO it is too early to buy new rotors unless you have evidence of warpage or grooving or glazing. Even turning the rotors is not necessary if there is no warpage at 3 years old. All this would be a 5 yr / 100k interval job (at the earliest) unless you have abused them. It is WAY conservative to rebuild the cylinders also - won't hurt, but not necessary. Typically turning Ford rotors is a recipe to cause warpage - since they were typically under-designed. The new rotors (05 and up) are beefier, so they may take to turning a lot better.
While I agree that replacing rotors is the best I think that unless they've been damaged (warped or cracked) it is a waste of your hard earned money unless they're worn down below specs.
The wear can be measured with a caliper. I don't know specifically what the wear limits are in our trucks but in many vehicles it is 2 mm. You can typically feel a lip developing at the outer edges of the rotor.
My '06 350 with 73K on it has exhibited very good wear characteristics. I would guess that I still have over 50% wear left.
As far as drilled vs. slotted vs. solid there are alot of opinions and most of them have no basis in physics. Brake rotors are heat sinks, transferring kenetic enegy into heat as they stop your truck. The larger (and heavier) your rotors are the better they can absorb the heat before they warp. So all things being equal the solid rotors will do a better job of absorbing heat than the lighter drilled and slotted ones.
Of course all things are not equal. When it rains there "can" be a thin layer that initially builds up on the rotor (until it gets hot enough to convert it to steam). Drilled rotors allow the water film to escape. They however also create significant weak spots that will, under heavy use, cause cracking that will significantly reduce their life.
Slotted rotors, if slotted correctly will allow the water film and also the gassing that is given off by the pads to disssipate.
If you look at any seriously built road racing cars there are no drilled rotors. They simply don't last. Most are running either slotted or solid rotors. I run solid rotors in my race car and have them cryogenitically treated for additional strength and wear improvements. Check out Frozen Rotors - High Performance Brake Pads, Brake Rotors if you want the best, longest lasting rotors....
Nice information guys. One question, what is the best way to flush your old brake fluid that you have found the easiest to do? I have tried every trick in the book but never liked one way in particular over the other. As a one man show, with no one around to help, I am always looking for new ideas.
i also would like to know the easiest method to flush the brake fluid system, and to bleed the system.........as always thanks for all the information.
this is off the subject, but i put my rig to the test this weekend, i pulled a 20,000lb fifth wheel this weekend to my deer lease, i no that way over loaded but she towed it with no problems, these truckd r awesome!!!!!!!!
The superduties will self bleed if you are in no hurry. Just go to the farthest wheel, right rear put a piece of clear tubing on the bleed valve and open it letting it drain into a suitable container. Put about a 1/4 " of fluid in the bottom of the drain cont. with the end of the clear hose in it. This will stop air from backing up into the wheel cylinder or caliper. Take the cap off of the master cylinder and go about your business if you have any menial tasks to do on the truck. Keep an eye on the fluid level of the mastercylinder. I don't let it get below the seam of the plastic mold. About 1/2 full. Top off as needed. The 1st wheel will take the longest. It will drain approx. 1 oz. per minute. When the fluid comes out clear, close the valve empty the container and go to left rear, repeat procedure and then r.f. and then l.f. I have a bleeder pump but I have ended up doing it this way. I'm usually in the workshop alone and this procedure is slow enough that nothing will get away from you.
.....this is off the subject, but i put my rig to the test this weekend, i pulled a 20,000lb fifth wheel this weekend to my deer lease, i no that way over loaded but she towed it with no problems, these truckd r awesome!!!!!!!!
That thing must be the Taj Mahal...How big is the hot tub ??
not the taj mahal, but its big, it measures 44' from nose to back of trailer, its just a big 3 axle toy hauler travel trailer......i wish it had a hot tub!!!!!!
I have replaced all four bleeder valves with speed bleeder valves (one way ball check valve)...works great. https://www.speedbleeder.com/. I picked mine up at Advance...they're also at Autozone, Pepboys, Carquest, etc...about $10 for two. I agree with most above comments...remove the caliper and re-lube or even replace glide pins and pad clip grooves...that way nothing getting hung up. Also, good ideal to pull your banjo bolts and ensure they're nice and clean.
Where I am corrosion is a severe issue, so cleaning of the parts and replacement is often driven by corrosion (e.g. inside the rotors).
In southern USA, that may not be an issue and brake components can last longer.
However, without a teardown of the calipers, it is often impossible to judge the extent of corrosion --- e.g. has it gone from the piston and corroded all the way inside PAST the contact point of the seals?
