Additive Headache
Old Nov 9, 2009 | 07:46 PM
scatgo's Avatar
scatgo
Originally Posted by pjwoolw
Its all about the copper injector sleeves. Thats the reason for a different coolant in these rigs. The 99.5 and up 7.3 has stainless steel sleeves. IIRC
Yep, If you look through the link Farm posted they state that you should not use some anti freez in pre 99's. Thanks Farm
Old Nov 9, 2009 | 07:50 PM
scatgo's Avatar
scatgo
Originally Posted by oldbird1965
Everytime I read these debates I wonder if my last decision on antifreeze was a good one. I wish someone would know for sure what to put into these trucks. By the way, where do you get the test stripes, my source ran out? Thanks
This is where I get them FLEETGUARD - COOLANT TEST STRIPS (4 PACK)-Dodge Cummins Diesel Truck Accessories – Geno’s Garage
They have the additive too.
Old Nov 9, 2009 | 07:56 PM
pjwoolw's Avatar
pjwoolw
Found a thread a while back with the spec. The key seems to be a low silicate coolant.
Old Nov 9, 2009 | 09:03 PM
FARM69's Avatar
FARM69
So are ELC coolants not recommended in our rigs?
Old Nov 9, 2009 | 09:19 PM
oldbird1965's Avatar
oldbird1965
Originally Posted by scatgo
Thanks a lot Scatgo, I appreciate that!
scatgo's Avatar
scatgo
That seems to be the case. Somthing about OAT's in the ELC. Organic Acid Technology. Bad for injector cups and other seals and stuff.
See post #3 in the link you gave..
Old Nov 9, 2009 | 09:22 PM
FARM69's Avatar
FARM69
Looks like I lucked out... I'm using Fleetcharge which is not a ELC.
I can't believe I didn't know about the OAT before. I know I looked into coolants when I did my flush a couple months back.
Old Nov 10, 2009 | 07:54 AM
MADVAN's Avatar
MADVAN
The late 466 had the SS sleeves (cups).
I have never seen a 7.3 (444) with SS sleeves (cups).
I would like to see a part#.
Bill
Old Nov 10, 2009 | 10:03 AM
pjwoolw's Avatar
pjwoolw
Sorry all. I thought I had read that there was a difference in the sleeve construction / material. Evidently not.
Thanks to Bill for correcting my brain f**t!
Old Nov 10, 2009 | 10:52 AM
scatgo's Avatar
scatgo
Well something has to be different that allowes the use of the ELC.
This is from the link that was posted..................
International's recommendation is based on extensive testing that showed compatibility issues with OAT-containing coolants and INJECTOR CUP MATERIAL, sensors, o-rings, gaskets, front cover, and probably some other things. However, engines made after 2/2/99 (SN 940614) were revised to be completely compatible with OAT-containing coolant.
You can read about it here, at page 2:
http://www.internationaldelivers.com...pdf/dyk299.pdf
Old Nov 10, 2009 | 11:16 AM
MADVAN's Avatar
MADVAN
Note HOAT and OAT
Cooling system maintenance
The cooling system on any diesel has special concerns. It's possible for the coolant to cavitate--produce tiny bubbles--that can with time cause pin holes throught the cylinder walls from the water jackets. For this there is an additive; Ford P/N FW-15 or FW-16, Fleetguard P/N DCA4; that needs to be maintained in the coolant. Generally this means installing 8 to 10 oz of the additive to the cooling system every 15000 miles. Another method is to monitor the cooling system with Fleetguard's DCA4 test kit P/N CC2602 or CC2602A. This measures the level of DCA4 in the system, then you add the amount of SCA/DCA as required to reach a nitrite level of 1.2-3.0 PPM. The cooling system should be drained (and flushed if you live in an area with especialy alkiline water) and refilled with a fresh 50/50 mix of coolant/distilled or demineralized water and one pint of the additive for every two gallons of coolant/water at 30,000 miles. Use only a ethylene glycol-based coolant, preferably low-silicate.
Antifreezes I can recommend:
Ford or Motorcraft Premium Antifreeze
Texaco Antifreeze/Coolant
Texaco Antifreeze/Coolant Prediluted 50/50
Zerex 5/100 (white bottle) Antifreeze/Coolant
Zerex Ready To Use Antifreeze/Coolant (premixed 50/50 with demineralized water)
Zerex Heavy Duty Precharged Formula
Shellzone Premium Quality Antifreeze
Prestone Heavy Duty (black bottle) Antifreeze/Coolant with SCA
Fleetguard Compleat EG--precharged at 1.5 units/gallon DCA4
Also available premixed 50/50 with water with the same DCA4 level
Pyroil Heavy-Duty Antifreeze/Coolant--Low Silicate
Peak Full Force or Advance
FleetCharge Antifreeze/Coolant--precharged with Pencool
WalMart Super Tech
2002 model year trucks use any of the above if your truck came filled with green coolant. If it came from the factory with yellow coolant, only use Motorcraft Premium Gold Long Life Antifreeze, Zerex G05 (gold bottle), Peak Global Lifetime (gold bottle) or Peak Extended Life CF-EXL (silver bottle). These coolants are fully-formulated using hybrid organic acid technology (HOAT) and do not require SCA/DCA. Recommended service interval with the gold coolant is 5 years or 100,000 miles. Test the gold coolant periodically for pH balance and freeze protection.
Trucks originally filled with Gold coolant:
All 2002 F-Series built at the Kentucky Truck Plant (VIN 11th digit "E")
2002 F150-550 built in Cuautitlan (VIN "M") from 2-4-02
2002 F650/750 built in Cuautitlan from 1-28-02
All Econolines built from 7-15-02
Ford has approved using the gold HOAT coolants in their vehicles as far back as the 1999 model year, providing the cooling system has been thoroughly flushed to remove all traces of the green coolant. If regular tap water is used instead of distilled or demineralized water, the recommended service interval is only 50,000 miles.
Ford does not recommend using propylene glycol-based coolants in any of their vehicles, or "universal" coolants that claim to be a replacement for any color antifreeze. They also have not approved the use of any organic acid tecnology (OAT) extended life coolants (ELC) in the PowerStroke cooling system.
Bill
Old Nov 10, 2009 | 05:51 PM
FARM69's Avatar
FARM69
Thanks for clearing that up Bill. I was running around with my head cut off lastnight until I finally found a bottle of the stuff that I'm using in my stroker. Luckily I have one that is approved.
Reps sent to ya!
TNGuy
Nov 27, 2016 08:14 AM
Tom
6.7L Power Stroke Diesel
Mar 6, 2011 08:08 PM
tdpower
15
Mar 1, 2011 11:39 PM
spdmpo
Jul 20, 2010 02:30 AM
Muktown
32
Nov 10, 2009 07:04 AM
