Rough ride?
Old Nov 25, 2009 | 07:26 PM
Toto's Avatar
Toto
Originally Posted by Huck BB62
Here's a common problem: The tires are inflated to the max when the truck is empty. No need.
Bingo...we have a winner!
Inflate to the load chart that comes with your truck according to load or inflate to the door sticker.
My 09 XLT with 18 inch tires rides like a limo...
BTW when I bought my 04 Cummins 2500, the back wheel were inflated to 70 psi by the dealer to cover their *** if I loaded heavy.
The inflation chart said 40 psi and 50 psi rear unloaded speeds over 60
Completely changed the ride of the truck from bouncing all over the road to very nice.
So check that preasure and good luck.
Old Nov 26, 2009 | 03:19 AM
stephen.osborne1's Avatar
stephen.osborne1
2wd or 4wd?
I didn't catch if you said your truck was 2wd or 4x4. 4x4 traditionally rides stiffer than 2wd, normally because of taller/stiffer springs.
Also, these newer trucks are using bigger wheels ( I think up to 22" now?) the taller the wheel, the better the truck will handle as far as turning and such, but since the taller wheel limits the maximum sidewall width, the tires must be "thinner". Obviously, with less sidewall, the tire has less "cushion". so if you have tall wheels and low profile tires, you might try a smaller wheel, bigger profile tire combo. you could test drive a similar truck with different wheel packages to see if you notice a difference.
Personally, I don't want any wheels over about 17 or 18", not because of the stiffer ride, but my trucks are both 4x4, and I want the added sidewall in to hit rocks and such off road, rather than my over priced huge wheels.
I haven't taken delivery of my '10 fx4 yet (January sometime they say) but my 2000 4x4 rides pretty well, and the 06-07's I have test driven in the past rode really well. None had over 17's on them. Good luck and congrats graduating from the civic to a "Man-toy".
Old Dec 4, 2009 | 05:04 PM
roegs's Avatar
roegs
Wow...I'm glad I found this post. My 2010 F150 Screw is my first Ford. I have the same concerns about ride. In my case, it seems every small road variation is felt in the floor. Overall, the ride is very smooth compared to my previous 3/4 ton truck, but it seems that small varations are not absorbed by the tires. To me its almost like a vibration that comes and goes based on road conditions. I have the 18 inch Goodyear Wrangers on mine. The dealer rebalanced with a Hunter road force balancer, and that helped some. In my case, the tires are P rated, which I would have assumed to have softer sidewalls. I've found that increasing tire pressure has actuall helped some. The dealer suggested driving another truck, which I'll do in the next week or so. In the end, I think a switch to a better tire like Michelin LTX would help.
Old Dec 21, 2009 | 06:17 PM
CountryBudTX's Avatar
CountryBudTX
It smooths out
I had a 2007 Ranger and now have a 2009 F-150 Crew Cab. I noticed the same harshness that you are mentioning. In both trucks at around 9-10k mi it seems to relax a little bit and gives you more of that smooth ride. I rode in a buddy's 08 Silverado and it rode very squishy... I've come to appreciate the firmness and feel of my Fords.
Old Dec 21, 2009 | 10:59 PM
roegs's Avatar
roegs
I lowered my tire air pressure from 35 lbs to 31 lbs and have noticed a significant increase in ride quality. It may sacrifice some MPG, but its worth it to me.
Estebanmarin92
Apr 28, 2017 06:39 PM
jackfordsd350
Aug 11, 2016 11:22 AM
ZackYoung
Jun 22, 2015 06:53 AM
351Cleveland C4
Apr 29, 2014 05:31 PM
kyle j
23
Jan 10, 2014 01:00 PM
