What can i do with my 2012 crew cab f250 so i font feel every bump i hit
I just got a f250 crew cab and i know that pick up is mostly used for heavy duty but what can i do to make the truck a smoother ride an not feel any little bump on the road that i hit. Please help
If it has the factory shocks replace them they suck and are likely worn out to boot popular choices here are bilstein 5100's rancho 9000's and fox 2.0's I think there called. But it's a heavy duty truck with a solid front axle it's not going to ride like an air ride caddy or even a f150 but you will be amazed at the difference good shocks make.
put Michelin 17" tires and rims. max air the tires will hold. replace the all (front and back)shocks with blistiens, see if you need rear anti sway bars.
