Air Dog 2 in Excursion Install Q's
Old Nov 7, 2009 | 08:49 PM
nghtrgr's Avatar
nghtrgr
Has anyone here installed the AD2 in their Excursion. If so here are my questions.
1) Was the supplied 1/2" ID push lock hose enough or did you require more?? I think I am about 2-3ft short, enough for a Super Duty not enough for the Ex.
2) How did you route the 1/2" fuel supply hose from the top of the tank?? Was the supplied 90degree fitting necessary??
3) How did you orient the air/vapor return line fitting that got spliced into the filler neck?? Up, down, forward and where did you route that hose.
Gonna drop the tank again tommorrow, good practice, to reroute the fuel supply hose that ended up in a bad place due to my eagerness to get done. Also going to relook the orientation of the air/vapor fitting and line routing.
Did the harpoon mod while I was in there, relatively easy.
Let me know what worked for you, Thanks
Diamond-X
Jan 27, 2019 07:26 AM
v8xploder
Paint & Bodywork
Jul 8, 2011 05:34 PM
Festus Hagen
20
Mar 21, 2011 10:35 AM
rickatic
6.7L Power Stroke Diesel
31
Oct 30, 2010 05:31 PM
