Hi guys,
I had the pump replaced in the rear gas tank (both pumps were out, front and rear) by a real lame mechanic. I had to take it back three times before I said f it. The problem is that when I put fuel in the rear tank , as I drive it the gas goes to the front tank. Hence I siphon from the front tank back into the rear tank. Could this be the switch F/R tank? Any help would be greatly appreciated.
