I like that idea too! I've seen the import tuners actually run Nitrous nozzles in front of the intercoolers to cool it down also without putting it in the fuel
Well you could use CO2, which they make a spray bar kit to shoot the cold charged CO2 at the intercooler, DEI, I think is the company that makes it. Look into them, cause around here you can get any size CO2 tank filled for 3 bucks, and I want to get there kit where it has a bulb inside a intake tube, so that the air is cooled down. Sounds like an intresting idea for us guys. Want me to get the link and info for you guys?
Yea. I've seen the CO2 kits before. They are neat.
They just mist the coolers and cool everything down.
This kit sounds neat, but ehh.
As for the fan stuff.
The fan always spins, its a slip clutch operated by a heat sensitive spring.
Thats why they eventually lock up, the spring stops being effected by hot and cold.
I've got more things to get done on my truck before I try this one out... My PHP chip should be here tomorrow, and then some Stage I injectors after that.
