Winch Mount
Old Nov 7, 2009 | 06:19 AM
hvacguy's Avatar
hvacguy
Winch Mount
Does anyone have pictures or recommendations for a brush guard type winch mount? I really don't want to replace the bumper, I prefer the bolt on type brush guard. I think this might be my next project on my 04 Ex.
Old Nov 7, 2009 | 09:33 AM
X-Hibition's Avatar
X-Hibition
One posssibility is a front receiver hitch so the winch is only there when you need it. And you keep the front bumper.
Old Nov 7, 2009 | 08:31 PM
soutthpaw's Avatar
soutthpaw
Check the specs on the guard carefully if you find one. Most are not made to handle a winch... Also the recommended standard is a winch with rated capacity 1 1/2 times the weight of the vehicle so you are at 12000 lb winch... You may find a hide a winch setup that usually just extends the stock bumper forward and then installs a mounting plate behind the bumper between the frame rails.
That being said, Winch ratings leave a lot to be desired.... for example a medium duty electric winch rated at 8K will probably outlast and out pull a 12K recreational rated winch like u see advertized in truck magazines...
the other choice is go old school like a Warn 8274... "the classic Jeep" winch.. if you check their site you will see it sells for over $2000 new even though its been made for like 3 decades or more now..... There is always a ****** block which will double the pulling capacity of the winch too. Are you actually planning on using it or as is often the case... have it for looks....
I have bought several used winches over the years and its amazing once u get past the dirt and grime and often the first layer of cable on the drum, the cable will look brand new...
bigb56
Jan 15, 2017 09:59 PM
Stalls
Aug 26, 2016 06:58 AM
GREEN 74 Highboy
Jun 30, 2015 04:42 PM
njneer1
1978 - 1996 Big Bronco
13
Dec 11, 2011 08:25 PM
Pro4x4
May 1, 2003 01:24 PM
