I-Beam Alignment
Old Nov 6, 2009 | 01:52 PM
Metallheadd's Avatar
Metallheadd
I-Beam Alignment
Does anyone know a good shop to get a frontend alignment on an IBeam 2WD Ford? Im near Statesville so a 50 mile radius would be good. Thanks
Old Nov 7, 2009 | 06:26 PM
Metallheadd
Anyone?? I know most places wont mess with the beams.
Old Nov 11, 2009 | 03:09 PM
fuzzy1626's Avatar
fuzzy1626
Ford stealership?
Old Nov 12, 2009 | 05:47 PM
Metallheadd
I got a price today $59.95 + $30.00 per bend. is that high or about right.
Old Nov 15, 2009 | 04:52 AM
jowilker's Avatar
jowilker
Are you sure your axle is bent??
John
Old Nov 15, 2009 | 10:11 AM
Metallheadd
No but I am getting heavy wear on the outside edge of my drivers side tire. About an 1 1/2" wide area.
Old Nov 15, 2009 | 05:29 PM
jowilker's Avatar
jowilker
You have had the toe set??
Whether the price is good or not, seems that that the above mentioned is the only place that you have found. Usually a tire shop that also deals in truck tires can do the I-beam bends. It is just unusual for an I-beam to be bent.
John
Old Nov 15, 2009 | 05:55 PM
Metallheadd
Is it? ok, well I have only ever had one other I-beam ford aligned but it was hit and definitly needed a bend. I guess I will take it in and see. No I have not had the toe adjusted.
1961mike
20
Feb 23, 2023 08:15 AM
72CC428
23
Nov 26, 2017 08:49 AM
I_Thnk_Ford
General Automotive Discussion
21
Jun 8, 2015 11:07 PM
ALedbetter1
Missouri Chapter
Feb 28, 2014 11:57 PM
j-marr1
Dec 16, 2013 03:28 PM
