1996 F150 Keyless Entry Issues
Old Nov 6, 2009 | 01:43 PM
DeathRowe's Avatar
DeathRowe
I have a '96 F-150 with some major keyless entry issues. Not sure how the problem started but here are the symptoms:
-When i put the key in and turn it to ON, the doors automatically lock.
-Cannot start truck unless i turn the ignition to start, press the kill button for the alarm, then start it. When i do this, all the lights on the dash come on, but after i hit the kill button, the ABS light goes out and truck starts right up.
-I dont have any working/programmed keyless entry remotes. I tried doing the on/off 8x to 10x method to program some old ones from other Fords, but nothing happens.
-The little red light on the dash blinks, but nothing else.
-The alarm will sound when the battery is disconnected and reconnected.
Can anyone offer any insight on how i can fix this? Is there a way that i can reset the entire module?
Old Nov 6, 2009 | 03:44 PM
DeathRowe's Avatar
DeathRowe
UPDATE: i solved the issue with pushing the kill button before starting. however, i still cant get the system to go into programming mode using the key-turning method. im looking in my shop manual repair cd which says there's a "remote keyless entry program connector" which i think might be the solution. anyone know where i could find this part?
pdombrowicki
6.4L Power Stroke Diesel
23
Sep 16, 2021 10:00 AM
pdombrowicki
Apr 10, 2012 01:37 PM
hescbr600
27
Jul 4, 2009 01:19 PM
Quackhead94ranger
1983 - 2012 Ranger & B-Series
May 22, 2005 02:33 PM
