Possible Starter or Ignition Switch?
Old Nov 9, 2009 | 01:28 PM
Wynn96's Avatar
Wynn96
Originally Posted by txmnjim
well, I cut back the wires on both terminals and they are clean...and
then it happened again! Almost late for work because of it ;-( Guess
I'll have to keep looking for the culprit.
jim
Happened to me a few months ago. Would just click sometimes. Crawl underneath and tug the wires that connect to the starter. Make sure that they are crimped good and tight. Turned out one of the wires had worked its way loose, and it pulled right out. Crimped it back together, and haven't had any trouble since.
Old Nov 9, 2009 | 05:07 PM
txmnjim's Avatar
txmnjim
Originally Posted by Ranger GT2
When it just clicks have you tried to leave the key in the ON position and jump across the large terminals of the starter solenoid? If it starts then it has to be something with the solenoid of not getting voltage to the solenoid from the ignition switch.
Thanks. I will try this.
jim
Old Nov 9, 2009 | 05:17 PM
txmnjim's Avatar
txmnjim
Originally Posted by gfw1985
Time for basic trouble shooting. Do you have a voltmeter or test light? Next time it doesn't start, jumper S term on starter relay to pos batt and feel if relay closes. If it does, jumper pos batt to starter lead. That will narrow it down a bit. If those fail it has to be the starter wire or starter. If those work, then you have to trace back towards ign switch. Observe all safety precautions!
Edit: I type slow
Thanks for the info. I will see what I can find with my test light. (I almost feel like just putting a new relay on to see what happens...I didn't
mention that it is so old that when I was "barely" re-tightening the connections this am after cleaning them, a small piece of the relay body
broke off!)
Jim
Old Nov 9, 2009 | 05:21 PM
txmnjim's Avatar
txmnjim
Thanks Wynn! I did this earlier and they seemed tight, but b4 I shell out
big $ for a starter I will definitely recheck them.
Jim
Old Nov 9, 2009 | 09:06 PM
8525ford's Avatar
8525ford
next time it clicks when you turn the key on. Have a buddy hold the key to the start pos. while you give the starter some taps with a hammer. if it cranks you got a bad starter. be carefull though. do not hold the key to the start pos longer than about 5-6 secs because the wire will start to melt, from heat. i have diagnosed alot of things with a crowbar and hammer. haha but thats just me. starting system on these trucks are soo basic. dont overthink this.
Old Nov 9, 2009 | 09:48 PM
txmnjim's Avatar
txmnjim
Thanks 8525! I will try this next time if someone's around ;-)
jim
Old Nov 10, 2009 | 08:44 PM
txmnjim's Avatar
txmnjim
Well it did it this morning and I got my DW to help. Not sure if she was
actually trying to crank it? (she said she was) but it didn't crank. Sooo
I think we will bite the bullet and replace the starter this weekend. (Guy
at work who used to work at a dealership said to "quit messin around and
just get another starter" ;-)
Jim
Old Nov 11, 2009 | 07:43 PM
txmnjim's Avatar
txmnjim
Well it acted up at a friends house who knows a lot about trucks/cars
today and we were able to jump the relay/solenoid with my jumper
cables. It started to turn over but starter was dragging real bad. My
friend thinks I just need to get another starter.
Jim
Old Nov 16, 2009 | 02:48 AM
txmnjim's Avatar
txmnjim
Happy to report that I was able to successfully change out my starter
Saturday! Now, hopefully I won't here the dreaded "click" again ;-)
Bad news is I *really* need to have my oil pan gasket replaced...it is
blown out in several places, one of which is right above the starter ;-(
Jim
Old Nov 16, 2009 | 12:00 PM
Ranger GT2's Avatar
Ranger GT2
Great to here you got it going. Hopefully you have the problem fixed and no more no starts.
Old Nov 16, 2009 | 09:17 PM
txmnjim's Avatar
txmnjim
Thanks! So far so good.
Jim
AtlM5
Dec 13, 2015 07:57 PM
hotrodharley84
May 21, 2013 12:17 PM
bigred66
2004 - 2008 F150
Sep 30, 2011 11:42 AM
dieselzen
Feb 9, 2011 01:24 AM
mxhowes1
Mar 3, 2008 10:05 PM
