1978 - 1996 Big Bronco
Front pumpkin gear oil
Old Nov 4, 2009 | 12:02 PM
3Nails's Avatar
3Nails
Have a '91, 5.0. The front pumpkin leaks a little bit. What weight gear oil do I need to add? Do I need a friction additive as well? Also, is there a safe additive that I can add to stop the small leak? Thanks.
Old Nov 4, 2009 | 12:48 PM
helirich's Avatar
helirich
80-90 is fine. If you have a Limited slip up there, add the modifier. There is no Bronco that came with a L/S in front stock. I dont know of a stop leak for a diff. I guess you could put 140 W in it. Might stop it leaking.
Old Nov 4, 2009 | 02:46 PM
DLP Performance's Avatar
DLP Performance
Ditto. You could put 'Lucas Gear Oil Stabilizer' in it, too.
Old Nov 4, 2009 | 06:07 PM
3Nails's Avatar
3Nails
Thanks a bunch....will use the 80-90 and watch it a little more closely.
LSO1123
Jan 5, 2014 06:30 AM
Louie3
1997 - 2003 F150
Feb 27, 2012 08:34 PM
lovemy7.3!
Mar 15, 2011 11:28 PM
79_250RangerLariat
Mar 23, 2009 11:00 PM
