86 F150 problems at stop lights
Old Nov 4, 2009 | 10:03 AM
gatorJ50's Avatar
gatorJ50
I have a1986 F150 that I inherited. My granddad bought it new off the lot in 87 and then he died in 89. it sat there at my grandmothers house, with a little bit of use by the neighbor, until my dad got it off of her in '98 or so. I started driving it 2 years ago when I got my license and it has always run fine, until recently. recently it has started this thing where it doesn't want to idle smooth at a stop light or anytime I have to stop completly. I often have to keep one foot on the gas. and then when I go to leave the light it does not want to go. it will start and then act like it is going to stall and I have to play games with the gas peddle to keep it from doing that very thing. it has gotten to where I don't pull out in front of any traffic at all.
I will now say that I know very little about working on engines but I was hoping that somebody on here would know of an easy (cheap) fix because I don't have the money to take it to anybody right now.
oh and it is just a straight 6 engine. nothing special.
thanks in advance!!!!!
Old Nov 4, 2009 | 01:02 PM
douglpr42's Avatar
douglpr42
please give size of motor . is it a carb. model or fuel injected manual or auto trans.
Old Nov 4, 2009 | 01:26 PM
gatorJ50's Avatar
gatorJ50
not sure about size or carb. motel. it is an automatic transmission.
I will get back to you about size and carb motel when I figure it out.
Old Nov 4, 2009 | 01:55 PM
JimsRebel's Avatar
JimsRebel
1986 F150 with a straight 6 would be a 300ci 4.9 liter with a feedback carb and an EEC IV IGN system.
Auto = a C6 trans
I would try installing a blocker plate under the EGR valve as a no-cost way to see is the EGR valve is leaking exh gases into the intake.
Jim
Old Nov 4, 2009 | 10:30 PM
douglpr42's Avatar
douglpr42
check for vacuum leaks
chandrabites
Jun 20, 2014 04:36 PM
jsutton
Nov 12, 2013 07:12 PM
Hellbore
May 23, 2006 05:22 PM
jjessen1
Aerostar
Aug 7, 2005 09:58 PM
04F150/OWNER
2004 - 2008 F150
Dec 14, 2004 10:57 PM
