Hello, does anyone know if you can use the engine plate that goes between the engine and transmission from a 351m, on 1 460? The 460 has a manual transmission engine plate, and I can't get the starter to bolt up to it because the holes are in the wrong location, and I have a junk 351m motor i can get the plate off of.
Hello, does anyone know if you can use the engine plate that goes between the engine and transmission from a 351m, on a 460? The 460 has a manual transmission engine plate, and I can't get the starter to bolt up to it because the holes are in the wrong location, and I have a junk 351m motor i can get the plate off of.
351M/400 vs 460 = The Ford part numbers are not the same, so I dunno whether the parts will interchange...or not.
the motor i have is out of a 71 lincoln I believe, but it was pulled out of a 79 f250 4x4. The 460 was attached to a four speed. Do you know any part numbers for a 71 460 with an automatic transmission?
