Headlight Issue, please help
Old Nov 3, 2009 | 12:41 PM
Illybey's Avatar
Illybey
Both of my headlights go off at the same time. The truck will run for about 5 minutes and then they both go off and then come back on after a second or 2. It does not happen as much in the cold, in the summer it happens very quickly but this morning was cooler outside and I made it all the way to work and they did not go off at all. I thought I would replace the relay-fuse, but they told me there wasn’t one when I went the parts store. They said there was only the switch, fuse, wires, and headlights. So I ordered the switch.
Old Nov 3, 2009 | 01:57 PM
Ronzi's Avatar
Ronzi
I once had that problem and replacing the dimmer switch on the floor cured it. Good luck to ya
Old Nov 3, 2009 | 02:28 PM
g0dl355's Avatar
g0dl355
I would think it's one of the switches or you have a loose connection somewhere.
Old Nov 3, 2009 | 02:54 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
What he said. This is a common problemo.
When activating the dimmer switch (it's on the floor below the parking brake control), if both headlamps lamps go out...it's time for a new dimmer switch.
COTZ13A024A .. Dimmer Switch-Foot Operated (Motorcraft SW263) / Fits myriad 1960/96 trucks/cars and etc.
Old Nov 3, 2009 | 07:17 PM
my774x4f250's Avatar
my774x4f250
I've also had the headlight switch go bad. I had a 76 and a 77 with the same problem.
