'05 Conversion
Old Nov 3, 2009 | 10:29 AM
krejci.mike's Avatar
krejci.mike
'05 Conversion
I wanted to do the '05 conversion with the headlights and grill, but I have a ranch hand front bumper. Anyone done this before? I'm wondering if the amount you cut is the same, since there is the small gap in between my grill and bumper.
Thanks,
Old Nov 3, 2009 | 10:35 AM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Thanks,
Can you post up some pics?
Old Nov 3, 2009 | 10:43 AM
jeff7825's Avatar
jeff7825
I would think you should be able to. The headlights should be no problem because they are a direct replacement, with a little cutting to the header panel. You may have to cut down the grille like you would if you were going to run the 05+ grille with the 99-04 bumper. That would depend on how much space is between your ranch hand bumper and your existing grille.
Old Nov 3, 2009 | 11:04 AM
krejci.mike
here are some pics
Old Nov 3, 2009 | 11:06 AM
Riffraff Diesel
PREMIUM SPONSOR
Oh yeah, you are fine Mike. I was picturing something different. The 05's are direct replacements for size so you shouldn't have any issues.
Old Nov 3, 2009 | 11:11 AM
krejci.mike
Is there a gap like that with the oem bumper and would I have to trim less of the grill?
Old Nov 3, 2009 | 11:13 AM
Riffraff Diesel
PREMIUM SPONSOR
Hey Mike, give me a call and I can walk you through it.
Old Nov 3, 2009 | 11:21 AM
PaysonPSD's Avatar
PaysonPSD
It appears you have plenty of room for an '05 grille without cutting as long as it clears the vetical diamond plate at the back off the bumper. Your only concern will be securing the bottom of the grille. The top of the '05 grille matches up perfectly with the mounting points of your stock grille.
Old Nov 3, 2009 | 12:07 PM
krejci.mike
That's what I wanted to hear! thanks.
Old Nov 3, 2009 | 12:08 PM
krejci.mike
Thanks for the offer. I hope to get one in the next couple of weeks so you might hear from me
Old Nov 3, 2009 | 12:23 PM
PaysonPSD's Avatar
PaysonPSD
Here is a LINK to cutting the grille to fit with stock pre-'05 bumper.
It will give you an idea of how much room you need.
hasteranger
Feb 22, 2015 08:33 AM
diehardstroker
Aug 25, 2013 05:50 PM
cheese20323
Oct 14, 2011 01:03 PM
daveboys
Apr 6, 2010 01:57 PM
h0rs3p0w3r
Sep 20, 2009 08:26 AM
