Factory Options
Old Nov 2, 2009 | 11:08 PM
dlogan3762's Avatar
dlogan3762
Factory Options
Does anyone know where I can find a list of factory options for 1986 F250.
Thanks in advance
Old Nov 3, 2009 | 01:28 AM
mds47588's Avatar
mds47588
Try purchasing a sales brochure from ebay. That will give the most accurate listing, the various paint and trim levels, and would be overall cool to have if you're planning on doing a restoration.
...been meaning to get on myself...
Old Nov 7, 2009 | 11:03 AM
MUSKY1011's Avatar
MUSKY1011
here ya go
Old Nov 7, 2009 | 06:04 PM
mds47588's Avatar
mds47588
AWESOME POST Musky1011!!
Thank you! I never knew of the so called "Victorian Two Tone".
Old Nov 7, 2009 | 09:41 PM
Bern_F150_4x4's Avatar
Bern_F150_4x4
Thumbs up
Musky1011, thanks for the post; rep points to you! If you get a chance post the whole doc in your gallery, I'm curious about the Trailer Towing/Camper Package.
Old Nov 7, 2009 | 10:09 PM
first today's Avatar
first today
My truck has the xlt victoria two tone.
Old Nov 7, 2009 | 10:37 PM
dlogan3762's Avatar
dlogan3762
Thanks for your post MUSKY1011. I also would like to see the Trailer Towing/Camper Special info if you have it.
Old Nov 8, 2009 | 09:10 AM
MUSKY1011's Avatar
MUSKY1011
Old Nov 8, 2009 | 06:05 PM
dlogan3762's Avatar
dlogan3762
Thanks again MUSKY1011, really appreciate your help.
Old Nov 9, 2009 | 08:59 AM
Diesel_Brad's Avatar
Diesel_Brad
Mine is the victorian 2 tone . From what i am told it was only available on an explorer pkg?
<a href="http://s108.photobucket.com/albums/n29/diesel_brad/?action=view&current=000_0755.jpg" target="_blank"><img src="http://i108.photobucket.com/albums/n29/diesel_brad/000_0755.jpg" border="0" alt="Photobucket"></a>
Old Nov 9, 2009 | 11:29 PM
DBrawley's Avatar
DBrawley
Here's a question about original factory equipment. How did one go about getting the under-hood tool box that can be seen in some of the pics in the "show what's under your hood thread? Anyone, anyone?
Old Nov 10, 2009 | 06:36 AM
Freaksh0w's Avatar
Freaksh0w
Someone on these forums did a write up on how they installed one into their truck that didn't originally have it.
Old Nov 10, 2009 | 10:10 AM
bghnkinf250's Avatar
bghnkinf250
Just food for thought - if you are looking for one, bring a cordless drill. There is a plate riveted to the fender to mount it to and the rivets need to be drilled out/chiseled off to get the plate off. I had to make 2 trips to the yard since I was unaware and had not read anywhere about it.
Old Nov 10, 2009 | 06:42 PM
ctubutis's Avatar
ctubutis
Sometimes this is true but not always. Unfortunately, I don't remember which
plates are riveted and which are bolted, e.g. is the donor a Bronco or a truck.
The bolts are 10mm, though.
Another thing... There is a supporting bracket that extends to the front radiator support, you
should get that, too. Make note (and also take) if the donor has large (1/2" or so) washers
between the box and washer fluid reservoir; some do, others don't. This is another case
where it depends if the donor is a Bronco or truck.
Old Nov 10, 2009 | 07:16 PM
bghnkinf250
I did not know that - mine was from a Bronco.
