F350 Side Mirror Signal Lense
Good luck pal! I've got an 03 with the same problem on the drivers side.
The biggest problem is (at least with my year model) that Ford doesn't just sell the lens...you have to buy the whole back cover to get the lens.
You might try posting for guys who have bought the Recon smoked lens and see if someone will sell you the ones they replaced.
Joe
Joe
$100 for 1 lense, you could get 2 lenses and change to smoke lenses if you wanted.
Recon Accessories: FORD SIDE Mirror Lenses
Brandon, I'm not sure on yours since you have the newer model towing mirrors. On mine, I tilted the mirror all the way towards the door window. Take a flashlight and look between the back cover and the mirror...on mine you see a series of plastic tabs. You have to CAREFULLY depress the tabs and work the back cover off of the mirror. Unplug the little wiring harness and you should be able to see the tabs to remove your amber section.
Let us know if you find something different on yours since it's a different model.
Joe
Joe
Hi guys, Finally got the Recon lenses in the mail and did the swap today. Wanted to give an update for anyone else that has problems or changes out their signal lenses. To get the factory lenses out all you have to do is slide a small flat screwdriver between the 2 mirrors, towards the outside edge of the mirror. If you look in there you can see a tab that holds the signal lense in. Just push the screw driver in and release the tab and the lense will pop right out. Takes 5 seconds once you know what you are doing. Hope this helps someone else out down the road. Cheers
90F250351
1999 to 2016 Super Duty
09-15-2009 07:59 PM
sumdumgai
05-03-2006 09:55 AM
