Cheap Repair
Old Nov 2, 2009 | 04:28 PM
FrankLeRoux's Avatar
FrankLeRoux
Cheap Repair
Hi!
This morning I've notice that my second fuel tank is leaking. I'm using the first one, but you know. So is there a cheap way to repair the fuel tank, it's only a little hole.
And forget about the Mighty Putty!
Thanks!
Old Nov 2, 2009 | 04:58 PM
quicklook2's Avatar
quicklook2
chewing gum
Old Nov 2, 2009 | 05:02 PM
FrankLeRoux
Originally Posted by quicklook2
chewing gum
Yeah! Bazooka Joe!
Old Nov 2, 2009 | 08:48 PM
*2fords*'s Avatar
*2fords*
I punched a small hole in one of the tanks on my 76 Chevy while 4 wheeling. I scraped a bar of soap across the hole a few times and it sealed it up. I eventually forgot about it and several years later I remembered it, and it was still sealed up. This is supposed to be a temporary fix, but it lasted all that time.
Old Nov 2, 2009 | 08:56 PM
9.ford.5's Avatar
9.ford.5
if your brave you can try a welder LOL i would not suggest it though...go to a truckstop, most of them sell stuff for fixing small holes in fuel tanks, i forgot what its called but it works wonders
Old Nov 2, 2009 | 09:13 PM
Jeff Dodson's Avatar
Jeff Dodson
JB WELD, that is what was used on the tank of my truck,
Old Nov 2, 2009 | 09:30 PM
HrdDrv's Avatar
HrdDrv
Vote me in on the soap repair. A quick fix when out on the road, just go to a service station restroom. Also the pantyhose trick fo a trashed belt. Just make sure she aint in 'em...
JB Weld is the cure, tho. Just make sure the area is clean. And No smoking.
Old Nov 3, 2009 | 01:35 AM
1994 F250: 351, C6's Avatar
1994 F250: 351, C6
JB Weld is good stuff. I prefer Quiksteel though, it is every bit as tough as JB weld but is easier to mix (just need it in your fingers) and is easier to apply into tight spots.
Old Nov 3, 2009 | 07:18 AM
F150xlt's Avatar
F150xlt
Here's a thread where I posted a method to repair pin hole leaks in a gas tank. Obviously there where people who posted a response that have never repaired a gas tank using solder.
The purpose of filling the tank with water is to displace the gas fumes remaining in the empty tank. Obviously you want to position the tank so water is not in contact with the area you're going to repair. Using a propane torch will allow a quick repair compared to using a soldering iron.
Click on the URL below to read the thread.
https://www.ford-trucks.com/forums/7...k-leaking.html
Old Nov 3, 2009 | 07:57 AM
B Dobz's Avatar
B Dobz
I had a pi hole and use a screw and cut a little piece of inner tub for a gasket and it`s been in there for 10 years and no problems.
yfz 450
Sep 30, 2013 07:17 PM
scole250
General Automotive Discussion
Oct 15, 2008 04:28 PM
bigperm2
1966 - 1977 Early Broncos
Feb 15, 2004 05:08 PM
jettfuel
1983 - 2012 Ranger & B-Series
Sep 22, 2002 05:15 PM
jdc48ford
Feb 10, 2002 12:58 AM
