Why does my truck hate me?????
Old Nov 1, 2009 | 10:32 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Well today I had to go pull my friends car out of a tree after he totaled it. ( Look for a new thread on that coming after this) I had to go threw a mud pit that was twice as high with mud then it was last time. I managed tlo kill a auto 2 times in the mud I was spinning the tires at about 45-60 then let off and the T/C stayed locked and killed it. So The O/D light was flashing and I am guessing that is because of the stalling. So here are all the codes I pulled off of it tonight,
P0478
P0670
P0683
P0720
P0722
And my favorite P1211...
What do all these codes mean. The truck seems to run fine so not sure whats up just the Check engine was on
Nick
Old Nov 1, 2009 | 10:40 PM
rbaker6336's Avatar
rbaker6336
0670 Glow Plug Module Control Circuit
0683 Glow Plug Control Module to PCM Communication Circuit
0720 Output Shaft Speed Sensor Circuit
0722 Output Shaft Speed Sensor Circuit No Signal
0478 Exhaust Pressure Control Valve High Input = Plugged sensor line, stuck butterfly??
1211 Injector Control Pressure Above/Below Desired = probly from chip
Old Nov 1, 2009 | 10:42 PM
hucka1a's Avatar
hucka1a
P0478 P0478 Exhaust Pressure Control Valve High Input
P0670 Glow plug Control Circuit Error
P0683 Glow Plug Control Module to PCM Communication Circuit
P0720 Output Speed Sensor Circuit Error
P0722 Output Speed Sensor No Signal
And my favorite P1211...ICP Not Ctrllable - Pressure Above/Desired
Nick
Here ya go. Edit: Ray's fast...
Old Nov 1, 2009 | 10:50 PM
weekendwarriorfsw32
Master of Strokes
Whats this speed sensor. If it not working why is the sped o working???
Old Nov 1, 2009 | 10:53 PM
hucka1a's Avatar
hucka1a
I'd clear the codes and see if any come back. I'd bet they came up because the truck stalled and died.
Old Nov 1, 2009 | 11:25 PM
PaysonPSD's Avatar
PaysonPSD
You've got it all wrong Nick. Your truck doesn't hate you, the mud hates your truck.
Like Huck said, clear the codes and see what comes back.
Here's a DTC list for ya.
File Type: pdf
Old Nov 1, 2009 | 11:36 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
P0478
P0670
P0683
P0720
P0722
Nick
I have highlighted the issue above.
Old Nov 1, 2009 | 11:45 PM
weekendwarriorfsw32
Master of Strokes
Sorry didn't feel like digging out the truck in the night in the mud. It was the only way to get threw it
Old Nov 2, 2009 | 12:14 AM
4inchlovin's Avatar
4inchlovin
When in doubt throttle out!!!
Old Nov 2, 2009 | 02:22 AM
WA.Ranger's Avatar
WA.Ranger
We need to lift that thing Nick...........I would throw her in 2nd gear next time and play with the throttle next time though.
Old Nov 2, 2009 | 08:28 AM
milleroutdoors's Avatar
milleroutdoors
Nick, Come up to the farm and I will give you pointers in the art of "point and shoot". I am sure with a lift and some good mud tires you could get stuck a lot farther from the road.
Old Nov 2, 2009 | 08:34 AM
robs01f250's Avatar
robs01f250
I have had to do the same thing, but luckily I got through it without any problems
http://i163.photobucket.com/albums/t...bsa4/photo.jpg
Old Nov 2, 2009 | 08:54 AM
SpringerPop's Avatar
SpringerPop
Just an off-hand guess:
If I recall, there are three "speed sensors" on our trucks that will set a code. The VSS is the most common failure, and it's the one that the speedometer is based upon.
The other two are shaft speed sensors that monitor things internal to the transmission. They're located on the top of the 4R100. The code you're seeing is likely indicating a failure of the rear one of those. Hopefully, the connector to it is only full of mud or water.
As I said, it's only a guess, and I did no in-depth research to arrive at this.
Pop
Old Nov 2, 2009 | 12:44 PM
duck fan's Avatar
duck fan
Because racetruck
The P0670 and P0683 are related to the GPCM. If after you clear the codes, those two come back, its time for a new GPCM. Its not a big deal until it starts getting cold. I am a bit sick of the SES light being on so I will probably replace mine soon.
Old Nov 2, 2009 | 12:46 PM
4inchlovin's Avatar
4inchlovin
Your truck dosnt hate you, you just pissed it off... My truck hates me!
